Converting SIP to SCCP - IP Phones
I'm with 797x SIP and I need converting to SCCP. What is the mode/method?
Best Regards
Peterson
  • IP Telephony
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Are you using CM or CME ?
Hi Paulo, how you doing?
I'm using CallManager 8.6. But I can to configure cme in a gateway.
You can remove/delete the SIP phones from CUCM and add it again as SCCP via Auto/Manual registration.
Siva
Pls rate if helps you.
Hi Siva
This method don't works, the phone try take the firmware but fail.
Hi Paulo
I dont known why your link was removed but thank you for you information.
http://www.cisco.com/en/US/products/hw/phones/ps379/products_tech_note09186a0080094584.shtml#siptosccp3
300
