Coporate Directories
I have a customer with a requirement to partition the corporate directory in such a way that each tenant can see only those extensions for whom they work. For example, tenant A can see tenant A employees and tenant B can only see tenant B employees. Anyone know how or if this is even possible?
1 REPLY
Re: Coporate Directories
Only by creating custom directories scripts and then, only assign the directory script to each phone as necessary. A lot of work to get that.
java
if this helps, please rate
java
www.cisco.com/go/pdi
118
