Community Member
Copy files from PC to Flash
Hello All,
Sorry to ask this questioon. We are palnning to upgrade the flash size for 500 gateways. Is there is any device to copy files from PC to Flash? like copying files to pendrive.?
-Murali
You can TFTP or use SCP.
Yosh
HTH Regards, Yosh
FTP too
+5 Yosh
Cheers
Carlo
Please rate all helpful posts
"The more you help the more you learn"
Please rate all helpful posts "The more you help the more you learn"
Community Member
TFTP/FTP appliation need to run on PC to copy the file, but my question is im not going to insert the flash in the router since they are located in different location. Im  going to send the flash to the location so that the local IT guy will replace the flash.
-Murali
Get a card reader and copy the files to the card.
Yosh
HTH Regards, Yosh
Purple
Hi Murali,
You need a router for that.
If the remote routers are same model, then, at one local site , you can copy image into flash of same router model one by one and then, send to remote locations.The engr. at remote site can just plugin and reboot the router.
regds,
aman
Community Member
Hi Yosh,
card reader can help on this? Can you please refer any company name?
Hi Murali.
With a compact flash card reader you can manage flash files mounting it on your pc as an external USB drive .
Here is a link on how to do it
http://www.cisco.com/c/en/us/td/docs/routers/access/1800/1841/software/configuration/guide/sw/b_cflash.html
Carlo
Exactly Carlo (+5) buddy
Yosh
HTH Regards, Yosh
Murali,
Transcen P8 is a 15 in 1 card reader and could be useful also for other purposes
Cheers
Carlo
334
