COR List and Dial Peer Problems
I have all of the COR lists and dial-peers set up properly, but my phones keep matching the 91[2-9]..[2-9]...... dial-peer instead of the 91900....... dial-peer which is assigned to another list. How many dial-peers do I have to configure for long distance in order to restrict 900 and 976 numbers from using the long distance dial-peers? Thanks, Tim
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Re: COR List and Dial Peer Problems
Hi Tim,
This link contains really good COR List references to 1-900 restrictions;
COR for Incoming/Outgoing Calls to Prevent Toll Fraud
From this excellent CME SRND doc;
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/products_implementation_design_guide_chapter09186a00805f07a8.html#wp1077232
Here is an excellent post from top NetPro Sankar that really explains COR Lists perfectly;
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=IP%20Telephony&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40%5E1%40%40.1ddcd15f/0#selected_message
Hope this helps!
Rob
Hi Tim,
Hope this helps!
Rob
Thanks for the references...I had my dialplan set up properly as Sankar suggested, but the after-hours sure does make the dial-peer configurations easier. Thanks, Tim
149
