cor list configuration
i am running a ccme and there are working call restrictions configured.I want to add an extension so that when i type 918 and 1 and the phone number of an office it will route the call to the office gateway (in another gateway) i typed the following commands but it is not working
dial-peer voice 1031 voip
corlist outgoing tel-sonema-filiales
description Appels BSIC Guinée Conakry
max-conn 1
destination-pattern 9181T
session target ipv4:10.10.3.6
codec g711ulaw
no vad
Any help
Hall of Fame Super Gold
Re: cor list configuration
What COR has to do with interoffice calls ?
You have to be more specific and mention in which sense it's not working.
Eg. the remote router will see a call coming for 918xxxxxxxx, you should strip some digits before it leaves the local router. Remember, voip DP doesn't do that automagically like a pots DP.
Thanks here is a working config, for eg when users want to call senegal they dial 904 and 1 AND IT works but i have not seen any digit stripping command in the config file.There is a new agency in another country i just need commands allowing me to dial 918 and 1 followed by their number to call them.That is what i want
Then digit stripping, or a proper destiona-pattern, is configured in the senegal router.
You have to do your troubleshooting as likely it's a matter do DP configuration, check "debug dialpeer" on both routers.
193
