COR List for Outgoing Calls to specific FXO POTS ports not working
                   I have a 1760 CME with one FXO card with two POTS lines comming into it. I found this COR list dial-plan that is supposed to make one extension always dial out on it's assigned FXO port. It is assigned it's outgoing port by the "answer-address 1001" or "answer-address 1002" statement. The dial plan works fine, for actual dialing. The problem is, it is not selecting the specific FXO port for whatever extension it is defined for. My plan here has ext 1001 using FXO port 2/1 and ext 1002 using FXO port 2/0. It seems it's just random on what port it uses when I dial out from either 1001 or 1002. Is there somewhere else I have to make a statement so that the "answer-address" definitly picks up on weather extension 1001 or 1002 is used?
dial-peer cor custom
name port21
name port20
dial-peer cor list use21
member port21
dial-peer cor list use20
member port20
dial-peer voice 100 pots
corlist outgoing use21
description 10 Digit Dialing
destination-pattern 9[2-9]..[2-9]......
port 2/1
forward-digits 10
dial-peer voice 101 pots
description Long Distance Dialing
destination-pattern 91..........
port 2/1
forward-digits 11
dial-peer voice 201 pots
corlist outgoing use20
port 2/0
forward-digits 10
dial-peer voice 202 pots
port 2/0
forward-digits 11
dial-peer voice 10 voip
corlist incoming use21
answer-address 1001
dial-peer voice 20 voip
corlist incoming use20
answer-address 1002
ephone-dn 1
number 1001
pickup-group 5000
name PHONE-1
call-forward busy 3000
call-forward noan 3000 timeout 14
ephone-dn 2
number 1002
pickup-group 5000
name PHONE-2
1 ACCEPTED SOLUTION
Green
Try using this
ephone-dn 1
number 1001
pickup-group 5000
name PHONE-1
ephone-dn 2
number 1002
pickup-group 5000
name PHONE-2
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
Green
Try using this
ephone-dn 1
number 1001
pickup-group 5000
name PHONE-1
ephone-dn 2
number 1002
pickup-group 5000
name PHONE-2
Alex.
Thanks so much for the fix. I knew the direction I wanted to take to fix my problem, I just didn't know where to make a change. Thanks again!!!
Green
Thank you for your rating.
It is all about learning.
You are very Welcome my friend.
Alex.
1175
