Community Member
Cor list in SIP phones
I set several corlist in CME 4.3 they work fine for SCCP phones. I have some liksys phone (SIP phones) in which I tried to apply some of these corlist but when I apply it I call still dial to the number I should not.
these are the config for corlist
dial-peer cor custom
name 9044
name 9045
name 901
name 900
name 9001
name local
name internas
dial-peer cor list Cell
member 9044
dial-peer cor list LADA
member 901
dial-peer cor list LADA-cell
member 9045
dial-peer cor list EU-CANADA
member 9001
dial-peer cor list Internacional
member 900
dial-peer cor list Ventas
member 9044
member 9045
member 901
member local
dial-peer cor list Ingenieria
member 9044
member 9045
member 901
member 900
member 9001
member local
for the sip phone I set
voice register pool 5
id mac 000E.08D0.4E75
number 1 dn 5
cor outgoing Cell 1 9044 ---> **I should just dial to cell phones but I can dial to any phone ***
dtmf-relay sip-notify
username 3252 password 3252
codec g711ulaw
dial-peer voice 202 pots
corlist outgoing Cell
description Cellular Calls
destination-pattern 9044..........
direct-inward-dial
port 0/2/0:1
prefix 044
there is something left in my config???
regards
1 ACCEPTED SOLUTION
Silver
Re: Cor list in SIP phones
Silver
Community Member
hi,
thanks a lot for your info,
now it works the corlist in linksys phone
the correct command is:cor incoming Cell default
regards
2994
