COR lists dont work
Hello.
I have two peers and next COR lists:
dial-peer voice 1000 voip
destination-pattern 100[0-4]
session protocol sipv2
session target ipv4:10.2.4.120
dtmf-relay rtp-nte
codec g711alaw
no vad
dial-peer voice 100 voip
translation-profile incoming 1
translation-profile outgoing 2
destination-pattern .T
session target sip-server
incoming called-number .
dtmf-relay rtp-nte
codec g711alaw
dial-peer cor custom
name Cisco_9971
name Cisco_7742
dial-peer cor list IN
member Cisco_7742
dial-peer cor list OUT
member Cisco_9971
member Cisco_7742
Wnen I am not using lists and dial 1003, i am get connected to peer 1000. Gets ok. But when I apply lists to DN and peer as:
ephone-dn  2
number 1020 no-reg primary
corlist incoming IN
corlist outgoing OUT
dtmf-relay rtp-nte
codec g711alaw
no vad
I am switched to peer 100 and router asks me to enter more numbers. When I dial 1003# to switch to dial 1000, I got fast busy signal. Please help me to investigate an issue.
Everyone's tags (2)
COR lists dont work
Please try below and lets see if it works
destination-pattern 100[0-4]$      ////// end your destination pattern with $
dtmf-relay rtp-nte
codec g711alaw
no vad
OR
destination-pattern 100[0-4]T     ////////// T will complete dialed number as soon as you press #
dtmf-relay rtp-nte
codec g711alaw
no vad
Nishant Savalia
Regards, Nishant Savalia
COR lists dont work
No(( As soon as I put COR list - peer is changed to 100((
COR lists dont work
Please share debug voip ccapi inout and running-config of your router.
Nishant Savalia
COR lists dont work
036999: Oct 15 14:18:33.859 UTC+2: //-1/BEAAE97E8BB9/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x337198F8, Call Info(
   Calling Number=1020,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE,
   Incoming Dial-peer=20011, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
037000: Oct 15 14:18:33.859 UTC+2: //-1/BEAAE97E8BB9/CCAPI/ccCheckClipClir:
   In: Calling Number=1020(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
037001: Oct 15 14:18:33.859 UTC+2: //-1/BEAAE97E8BB9/CCAPI/ccCheckClipClir:
   Out: Calling Number=1020(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
037002: Oct 15 14:18:33.871 UTC+2: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
037003: Oct 15 14:18:33.871 UTC+2: :cc_get_feature_vsa malloc success
037004: Oct 15 14:18:33.871 UTC+2: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
037005: Oct 15 14:18:33.871 UTC+2:  cc_get_feature_vsa count is 1
037006: Oct 15 14:18:33.871 UTC+2: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
037007: Oct 15 14:18:33.871 UTC+2: :FEATURE_VSA attributes are: feature_name:0,feature_time:919303744,feature_id:28344
037008: Oct 15 14:18:33.871 UTC+2: //65034/BEAAE97E8BB9/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=1020(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=(TON=Unknown, NPI=Unknown))
037009: Oct 15 14:18:33.879 UTC+2: //-1/xxxxxxxxxxxx/CCAPI/cc_build_feature_vsa:
037010: Oct 15 14:18:33.891 UTC+2: :Inside cc_build_feature_vsa
037011: Oct 15 14:18:33.891 UTC+2: //-1/xxxxxxxxxxxx/CCAPI/cc_build_feature_vsa:
037012: Oct 15 14:18:33.891 UTC+2:  feature call basic
037013: Oct 15 14:18:33.891 UTC+2: //-1/xxxxxxxxxxxx/CCAPI/cc_build_feature_vsa:
037014: Oct 15 14:18:33.891 UTC+2: cc_build_feature_vsa attr is fn:TWC,ft:10/15/2013 14:18:33.871,cgn:1020,cdn:,frs:0,fid:28344,fcid:BEAAE97E34CA11E38BB983E66A2C4466,legID:FE0A
037015: Oct 15 14:18:33.943 UTC+2: //65034/BEAAE97E8BB9/CCAPI/cc_process_call_setup_ind:
   Event=0x320F2B28
037016: Oct 15 14:18:33.943 UTC+2: //65034/BEAAE97E8BB9/CCAPI/ccCallSetContext:
   Context=0x36D13290
037017: Oct 15 14:18:33.943 UTC+2: //65034/BEAAE97E8BB9/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 65034 with tag 20011 to app "_ManagedAppProcess_Default"
037018: Oct 15 14:18:33.967 UTC+2: //65034/BEAAE97E8BB9/CCAPI/ccCallSetupAck:
   Call Id=65034
037019: Oct 15 14:18:33.967 UTC+2: //65034/BEAAE97E8BB9/CCAPI/cc_api_set_transfer_info:
   Transfer Number=, Transfer Reason=0x0
037020: Oct 15 14:18:33.967 UTC+2: //65034/BEAAE97E8BB9/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=TRUE, Tone=Dial Tone,
   Tone Direction=Network, Params=0x0, Call Id=65034
037021: Oct 15 14:18:33.967 UTC+2: //65034/BEAAE97E8BB9/CCAPI/ccSetDigitTimeouts:
   Initial Digit Timeout=-1000(ms), Inter Digit Timeout=-1000(ms)
037022: Oct 15 14:18:33.967 UTC+2: //65034/BEAAE97E8BB9/CCAPI/ccSetDigitTimeouts:
   Call Entry(Inter Digit Timeout=10000(ms), Initial Digit Timeout=10000(ms))
037023: Oct 15 14:18:33.967 UTC+2: //65034/BEAAE97E8BB9/CCAPI/ccCallReportDigits:
   (callID=0xFE0A, digit_event=0x1, enable=TRUE, consume=FALSE)
037024: Oct 15 14:18:33.967 UTC+2: //65034/BEAAE97E8BB9/CCAPI/ccCallReportDigits:
   Enabled=TRUE, Call Id=65034
037025: Oct 15 14:18:33.975 UTC+2: //65034/BEAAE97E8BB9/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x337198F8, callID=0xFE0A, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
037026: Oct 15 14:18:33.975 UTC+2: //65034/BEAAE97E8BB9/CCAPI/cc_api_call_report_digits_done:
   Enabled=TRUE, Disposition=0x0, Interface=0x337198F8, Call Id=65034
037027: Oct 15 14:18:33.975 UTC+2: //65034/BEAAE97E8BB9/CCAPI/cc_api_call_report_digits_done:
   Call Entry(Initial Digit Timeout=15000(ms), Inter Digit Timeout=10000(ms))
037028: Oct 15 14:18:34.051 UTC+2: //65034/BEAAE97E8BB9/CCAPI/cc_api_call_digit_begin:
   Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
   Source Call Id=65034, Digit=1, DigitBeginFlags=0x0,
   Rtp Timestamp=0x70FDC8, Rtp Expiration=0x0
037029: Oct 15 14:18:34.063 UTC+2: //65034/BEAAE97E8BB9/CCAPI/cc_api_call_digit_end:
   Source Call Id=65034, Digit=1, Duration=100,
   Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF
037030: Oct 15 14:18:34.063 UTC+2: //65034/BEAAE97E8BB9/CCAPI/cc_api_call_digit_end:
   Call Entry(Handoff Depth=0)
037031: Oct 15 14:18:34.479 UTC+2: //65034/BEAAE97E8BB9/CCAPI/cc_api_call_digit_begin:
   Source Call Id=65034, Digit=0, DigitBeginFlags=0x0,
   Rtp Timestamp=0x717AC8, Rtp Expiration=0x0
037032: Oct 15 14:18:34.479 UTC+2: //65034/BEAAE97E8BB9/CCAPI/cc_api_call_digit_end:
   Source Call Id=65034, Digit=0, Duration=100,
037033: Oct 15 14:18:34.487 UTC+2: //65034/BEAAE97E8BB9/CCAPI/cc_api_call_digit_end:
037034: Oct 15 14:18:34.691 UTC+2: //65034/BEAAE97E8BB9/CCAPI/cc_api_call_digit_begin:
   Rtp Timestamp=0x71F7C8, Rtp Expiration=0x0
037035: Oct 15 14:18:34.691 UTC+2: //65034/BEAAE97E8BB9/CCAPI/cc_api_call_digit_end:
037036: Oct 15 14:18:34.691 UTC+2: //65034/BEAAE97E8BB9/CCAPI/cc_api_call_digit_end:
037037: Oct 15 14:18:35.115 UTC+2: //65034/BEAAE97E8BB9/CCAPI/cc_api_call_digit_begin:
   Source Call Id=65034, Digit=3, DigitBeginFlags=0x0,
   Rtp Timestamp=0x7274C8, Rtp Expiration=0x0
037038: Oct 15 14:18:35.115 UTC+2: //65034/BEAAE97E8BB9/CCAPI/cc_api_call_digit_end:
   Source Call Id=65034, Digit=3, Duration=100,
037039: Oct 15 14:18:35.127 UTC+2: //65034/BEAAE97E8BB9/CCAPI/cc_api_call_digit_end:
037040: Oct 15 14:18:35.879 UTC+2: //65034/BEAAE97E8BB9/CCAPI/cc_api_call_digit_begin:
   Source Call Id=65034, Digit=#, DigitBeginFlags=0x0,
   Rtp Timestamp=0x72F1C8, Rtp Expiration=0x0
037041: Oct 15 14:18:35.887 UTC+2: //65034/BEAAE97E8BB9/CCAPI/cc_api_call_digit_end:
   Source Call Id=65034, Digit=#, Duration=100,
037042: Oct 15 14:18:35.887 UTC+2: //65034/BEAAE97E8BB9/CCAPI/cc_api_call_digit_end:
037043: Oct 15 14:18:35.899 UTC+2: //65034/BEAAE97E8BB9/CCAPI/ccCallReportDigits:
   (callID=0xFE0A, digit_event=0x0, enable=FALSE, consume=FALSE)
037044: Oct 15 14:18:35.899 UTC+2: //65034/BEAAE97E8BB9/CCAPI/ccCallReportDigits:
037045: Oct 15 14:18:35.899 UTC+2: //65034/BEAAE97E8BB9/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x337198F8, callID=0xFE0A, disp=0, digit_event=0x0, enable=FALSE, consume=FALSE)
037046: Oct 15 14:18:35.899 UTC+2: //65034/BEAAE97E8BB9/CCAPI/cc_api_call_report_digits_done:
037047: Oct 15 14:18:35.899 UTC+2: //65034/BEAAE97E8BB9/CCAPI/cc_api_call_report_digits_done:
037048: Oct 15 14:18:35.919 UTC+2: //65034/BEAAE97E8BB9/CCAPI/ccCallProceeding:
   Progress Indication=NULL(0)
037049: Oct 15 14:18:35.943 UTC+2: //65034/BEAAE97E8BB9/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=100, Params=0x36C6C1E0, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
037050: Oct 15 14:18:35.943 UTC+2: //65034/BEAAE97E8BB9/CCAPI/ccCheckClipClir:
   In: Calling Number=2202001(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
037051: Oct 15 14:18:35.951 UTC+2: //65034/BEAAE97E8BB9/CCAPI/ccCheckClipClir:
   Out: Calling Number=2202001(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
037052: Oct 15 14:18:35.951 UTC+2: //65034/BEAAE97E8BB9/CCAPI/ccCallSetupRequest:
   Destination Pattern=.T, Called Number=1003, Digit Strip=FALSE
037053: Oct 15 14:18:35.951 UTC+2: //65034/BEAAE97E8BB9/CCAPI/ccCallSetupRequest:
   Calling Number=2202001(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=1003(TON=Unknown, NPI=Unknown),
   Redirect Number=, Display Info=
   Account Number=, Final Destination Flag=FALSE,
   Guid=BEAAE97E-34CA-11E3-8BB9-83E66A2C4466, Outgoing Dial-peer=100
037054: Oct 15 14:18:35.951 UTC+2: //65034/BEAAE97E8BB9/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   ----- ccCallInfo IE subfields -----
   cisco-ani=2202001
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=1003
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
   cisco-redirectreason=0   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
037055: Oct 15 14:18:35.951 UTC+2: //65034/BEAAE97E8BB9/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x31CD6A14, Interface Type=3, Destination=, Mode=0x0,
   Call Params(Calling Number=2202001,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=1003(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE, Outgoing Dial-peer=100, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
037056: Oct 15 14:18:35.963 UTC+2: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
037057: Oct 15 14:18:35.963 UTC+2: :cc_get_feature_vsa malloc success
037058: Oct 15 14:18:35.963 UTC+2: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
037059: Oct 15 14:18:35.963 UTC+2:  cc_get_feature_vsa count is 2
037060: Oct 15 14:18:35.963 UTC+2: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
037061: Oct 15 14:18:35.963 UTC+2: :FEATURE_VSA attributes are: feature_name:0,feature_time:919294112,feature_id:28345
037062: Oct 15 14:18:35.975 UTC+2: //65035/BEAAE97E8BB9/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=3, FlowMode=1
037063: Oct 15 14:18:35.975 UTC+2: //65035/BEAAE97E8BB9/CCAPI/ccCallSetContext:
   Context=0x36C6C190
037064: Oct 15 14:18:35.975 UTC+2: //65034/BEAAE97E8BB9/CCAPI/ccSaveDialpeerTag:
037065: Oct 15 14:18:36.027 UTC+2: //65035/BEAAE97E8BB9/CCAPI/cc_api_call_proceeding:
   Interface=0x31CD6A14, Progress Indication=NULL(0)
037066: Oct 15 14:18:36.059 UTC+2: //-1/xxxxxxxxxxxx/CCAPI/cc_build_feature_vsa:
037067: Oct 15 14:18:36.059 UTC+2: :Inside cc_build_feature_vsa
037068: Oct 15 14:18:36.059 UTC+2: //-1/xxxxxxxxxxxx/CCAPI/cc_build_feature_vsa:
037069: Oct 15 14:18:36.059 UTC+2:  feature call basic
037070: Oct 15 14:18:36.059 UTC+2: //-1/xxxxxxxxxxxx/CCAPI/cc_build_feature_vsa:
037071: Oct 15 14:18:36.059 UTC+2: cc_build_feature_vsa attr is fn:TWC,ft:10/15/2013 14:18:35.963,cgn:2202001,cdn:1003,frs:0,fid:28345,fcid:BEAAE97E34CA11E38BB983E66A2C4466,legID:FE0B
037072: Oct 15 14:18:36.391 UTC+2: //65035/BEAAE97E8BB9/CCAPI/cc_api_call_cut_progress:
   Interface=0x31CD6A14, Progress Indication=INBAND(8), Signal Indication=SIGNAL RINGBACK(1),
   Cause Value=0
037073: Oct 15 14:18:36.391 UTC+2: //65035/BEAAE97E8BB9/CCAPI/cc_api_call_cut_progress:
   Call Entry(Responsed=TRUE)
037074: Oct 15 14:18:36.391 UTC+2: //65034/BEAAE97E8BB9/CCAPI/ccCallCutProgress:
   Progress Indication=INBAND(8), Signal Indication=SIGNAL RINGBACK(1), Cause Value=0
   Voice Call Send Alert=FALSE, Call Entry(Alert Sent=FALSE)
037075: Oct 15 14:18:36.391 UTC+2: //65034/BEAAE97E8BB9/CCAPI/ccCallCutProgress:
037076: Oct 15 14:18:36.403 UTC+2: //65034/BEAAE97E8BB9/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=FALSE, Tone=Null,
037077: Oct 15 14:18:36.403 UTC+2: //65034/BEAAE97E8BB9/CCAPI/ccConferenceCreate:
   (confID=0xFFFFFFFF, callID1=0xFE0A, gcid=BEAAE97E-34CA11E3-8BB983E6-6A2C4466, tag=0x0)
037078: Oct 15 14:18:36.403 UTC+2: //65035/BEAAE97E8BB9/CCAPI/ccConferenceCreate:
   (confID=0xFFFFFFFF, callID2=0xFE0B, gcid=BEAAE97E-34CA11E3-8BB983E6-6A2C4466, tag=0x0)
037079: Oct 15 14:18:36.403 UTC+2: //65034/BEAAE97E8BB9/CCAPI/ccConferenceCreate:
   Conference Id=0xFFFFFFFF, Call Id1=65034, Call Id2=65035, Tag=0x0
037080: Oct 15 14:18:36.403 UTC+2: //65034/BEAAE97E8BB9/CCAPI/cc_api_bridge_done:
   Conference Id=0x208, Source Interface=0x337198F8, Source Call Id=65034,
   Destination Call Id=65035, Disposition=0x0, Tag=0xFFFFFFFF
037081: Oct 15 14:18:36.403 UTC+2: //65035/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
037082: Oct 15 14:18:36.411 UTC+2: cc_api_get_xcode_stream : 4819
037083: Oct 15 14:18:36.411 UTC+2: //65035/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
037084: Oct 15 14:18:36.411 UTC+2: cc_api_get_xcode_stream : 4819
037085: Oct 15 14:18:36.415 UTC+2: //65035/BEAAE97E8BB9/CCAPI/cc_api_bridge_done:
   Conference Id=0x208, Source Interface=0x31CD6A14, Source Call Id=65035,
   Destination Call Id=65034, Disposition=0x0, Tag=0x0
037086: Oct 15 14:18:36.415 UTC+2: //65034/BEAAE97E8BB9/CCAPI/cc_generic_bridge_done:
037087: Oct 15 14:18:36.415 UTC+2: //65034/BEAAE97E8BB9/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x208, Destination Call Id=65035)
037088: Oct 15 14:18:36.415 UTC+2: //65035/BEAAE97E8BB9/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x208, Destination Call Id=65034)
037089: Oct 15 14:18:36.423 UTC+2: //65034/BEAAE97E8BB9/CCAPI/ccConferenceCreate:
037090: Oct 15 14:18:36.423 UTC+2: confID:0x208; callEntry1 callID1:0xFE0A, type:6; callEntry2 callID2:0xFE0B, type:3
037091: Oct 15 14:18:36.423 UTC+2: //65034/BEAAE97E8BB9/CCAPI/cc_api_caps_ind:
   Destination Interface=0x31CD6A14, Destination Call Id=65035, Source Call Id=65034,
   Caps(Codec=0x1, Fax Rate=0x1, Fax Version:=0, Vad=0x1,
   Modem=0x0, Codec Bytes=20, Signal Type=3)
037092: Oct 15 14:18:36.423 UTC+2: //65034/BEAAE97E8BB9/CCAPI/cc_api_caps_ind:
   Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
   Playout Max=1000(ms), Fax Nom=300(ms))
037093: Oct 15 14:18:36.435 UTC+2: //65035/BEAAE97E8BB9/CCAPI/cc_api_caps_ind:
   Destination Interface=0x337198F8, Destination Call Id=65034, Source Call Id=65035,
   Caps(Codec=0x2, Fax Rate=0x2, Fax Version:=0, Vad=0x2,
   Modem=0x0, Codec Bytes=160, Signal Type=2)
037094: Oct 15 14:18:36.435 UTC+2: //65035/BEAAE97E8BB9/CCAPI/cc_api_caps_ind:
037095: Oct 15 14:18:36.435 UTC+2: //65035/BEAAE97E8BB9/CCAPI/cc_api_caps_ack:
   Caps(Codec=g711alaw(0x2), Fax Rate=FAX_RATE_VOICE(0x2), Fax Version:=0, Vad=ON(0x2),
   Modem=OFF(0x0), Codec Bytes=160, Signal Type=2, Seq Num Start=5047)
037096: Oct 15 14:18:36.443 UTC+2: //65034/BEAAE97E8BB9/CCAPI/cc_api_caps_ack:
037097: Oct 15 14:18:36.455 UTC+2: //65034/BEAAE97E8BB9/CCAPI/ccCallFeature:
   Feature Type=25, Call Id=65034
037098: Oct 15 14:18:36.499 UTC+2: //65034/BEAAE97E8BB9/CCAPI/cc_api_voice_mode_event:
   Call Id=65034
037099: Oct 15 14:18:36.499 UTC+2: //65034/BEAAE97E8BB9/CCAPI/cc_api_voice_mode_event:
   Call Entry(Context=0x36D13290)
037100: Oct 15 14:18:36.511 UTC+2: //65034/BEAAE97E8BB9/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x208, Call Id1=65034, Call Id2=65035
037101: Oct 15 14:18:36.791 UTC+2: //65035/BEAAE97E8BB9/CCAPI/cc_api_call_disconnected:
   Cause Value=28, Interface=0x31CD6A14, Call Id=65035
037102: Oct 15 14:18:36.791 UTC+2: //65035/BEAAE97E8BB9/CCAPI/cc_api_call_disconnected:
   Call Entry(Responsed=TRUE, Cause Value=28, Retry Count=0)
037103: Oct 15 14:18:36.803 UTC+2: //65034/BEAAE97E8BB9/CCAPI/ccCallReleaseResources:
   release reserved xcoding resource.
037104: Oct 15 14:18:36.803 UTC+2: //65035/BEAAE97E8BB9/CCAPI/ccCallSetAAA_Accounting:
   Accounting=0, Call Id=65035
037105: Oct 15 14:18:36.803 UTC+2: //65034/BEAAE97E8BB9/CCAPI/ccConferenceDestroy:
   Conference Id=0x208, Tag=0x0
037106: Oct 15 14:18:36.811 UTC+2: //65034/BEAAE97E8BB9/CCAPI/ccConferenceDestroy:
037107: Oct 15 14:18:36.811 UTC+2: confID:0x208; callEntry1 callID1:0xFE0A, type:6; callEntry2 callID2:0xFE0B, type:3
037108: Oct 15 14:18:36.811 UTC+2: //65034/BEAAE97E8BB9/CCAPI/cc_api_bridge_drop_done:
   Destination Call Id=65035, Disposition=0x0, Tag=0x0
037109: Oct 15 14:18:36.811 UTC+2: //65035/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
037110: Oct 15 14:18:36.811 UTC+2: cc_api_get_xcode_stream : 4819
037111: Oct 15 14:18:36.811 UTC+2: //65034/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
037112: Oct 15 14:18:36.811 UTC+2: cc_api_get_xcode_stream : 4819
037113: Oct 15 14:18:36.811 UTC+2: //65035/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
037114: Oct 15 14:18:36.811 UTC+2: cc_api_get_xcode_stream : 4819
037115: Oct 15 14:18:36.815 UTC+2: //65035/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
037116: Oct 15 14:18:36.815 UTC+2: cc_api_get_xcode_stream : 4819
037117: Oct 15 14:18:36.815 UTC+2: //65035/BEAAE97E8BB9/CCAPI/cc_api_bridge_drop_done:
037118: Oct 15 14:18:36.823 UTC+2: //65034/BEAAE97E8BB9/CCAPI/cc_generic_bridge_done:
037119: Oct 15 14:18:36.887 UTC+2: //65035/BEAAE97E8BB9/CCAPI/ccCallDisconnect:
   Cause Value=28, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=28)
037120: Oct 15 14:18:36.887 UTC+2: //65035/BEAAE97E8BB9/CCAPI/ccCallDisconnect:
   Cause Value=28, Call Entry(Responsed=TRUE, Cause Value=28)
037121: Oct 15 14:18:36.919 UTC+2: //65035/BEAAE97E8BB9/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x31CD6A14, Tag=0x0, Call Id=65035,
   Call Entry(Disconnect Cause=28, Voice Class Cause Code=0, Retry Count=0)
037122: Oct 15 14:18:36.919 UTC+2: //65035/BEAAE97E8BB9/CCAPI/cc_api_call_disconnect_done:
   Call Disconnect Event Sent
037123: Oct 15 14:18:36.931 UTC+2: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
037124: Oct 15 14:18:36.931 UTC+2: :cc_free_feature_vsa freeing 36CB5098
037125: Oct 15 14:18:36.931 UTC+2: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
037126: Oct 15 14:18:36.931 UTC+2:  vsacount in free is 1
037127: Oct 15 14:18:36.963 UTC+2: //65034/BEAAE97E8BB9/CCAPI/ccCallDisconnect:
   Cause Value=28, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
037128: Oct 15 14:18:36.963 UTC+2: //65034/BEAAE97E8BB9/CCAPI/ccCallDisconnect:
037129: Oct 15 14:18:36.975 UTC+2: //65034/BEAAE97E8BB9/CCAPI/cc_api_get_transfer_info:
   Transfer Number=NULL
037130: Oct 15 14:18:37.575 UTC+2: //65034/BEAAE97E8BB9/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x337198F8, Tag=0x0, Call Id=65034,
037131: Oct 15 14:18:37.575 UTC+2: //65034/BEAAE97E8BB9/CCAPI/cc_api_call_disconnect_done:
037132: Oct 15 14:18:37.575 UTC+2: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
037133: Oct 15 14:18:37.575 UTC+2: :cc_free_feature_vsa freeing 36CB7638
037134: Oct 15 14:18:37.575 UTC+2: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
037135: Oct 15 14:18:37.575 UTC+2:  vsacount in free is 0
COR lists dont work
Why do you press # at the end ?
Try not to press # and let the interdigit timeout happens which is 10 sec and see which dial peer is being selected.
If still it does not work then try as below:-
destination-pattern 1003$      ////// end your destination pattern with $
dtmf-relay rtp-nte
codec g711alaw
no vad
destination-pattern [2-9].T
dtmf-relay rtp-nte
codec g711alaw
Nishant Savalia
COR lists dont work
But why the peer is changed when I apply COR list??? If I dial the same number.
COR lists dont work
Please share again debug voip ccapi inout without cor list and also share your running-config too.
Nishant Savalia
291
