Core Dump File
Hi Guys,
I have a call manager buniess edition 7.1.3b that's in pre-production testing and all of a sudden the call manager service restarted itself.  I had RTMT open at the time and got a "core dump file" message.
I retrieved the core dump file but I've no idea how to read it.
Is this file of any use to anyone apart from TAC?
Thanks in advance,
Neil
1 REPLY
Re: Core Dump File
The core file itself usually is only of value to TAC.  However the backtrace which you can generate from the core file "utils core active analyze " can be of use to anyone.  Search the bug toolkit for lines from the backtrace and you may be able to find the cause of the core.
654
