Corlist configurations on H323 FXS?
I have a CCM with a H323 gateway. This gateway also has some FXS ports. Is it possible to restrict this ports to only be able to dial internally?
I have something like this, but I do not know where to apply the Cor incoming command. This is not a CCME where i can apply it to the Ephones.
Dial-peer cor custom
name internal
name external
Dial-peer cor list internal
member InternalCall
dial-peer cor list external
member ExternalCall
dial-peer voice 1001 voip
destination-pattern 8...
session target ipv4:10.93.161.10
corlist outgoing InternalCall
dial-peer voice 1 pots
destination-pattern 9T
port 0/2/0:15
corlist outgoing ExternalCall
If this doesn't work, I have an idea is to match calls starting with the external access code, 9, to a dummy number like 12345 to fail the call.
(luckily my extensions don't start with 9)
Thanks all for your time. :)
Eugene
206
