CORLIST for calls through E1 PRI
I have a site where in voice gateway there are two different E1 PRIs, each with a different DDI range. Due to the different DDI range for each PRI and hence to display properCLID for outgoing calls,  an outgoing call must go out the same PRI to which it DDI randi is attached.
How is this possible? Is this by applying a corlist? Is there any other better easier way?
Blue
Hi Rajesh
One way is to prefix the call originated from Let say DID A user with a unique number (its DID common number as an example) by doing translation rule/CUCM configuration and then you select which PRI to use on the
gateway based on matching that number with the right pots dial-peer and you strip the unique digits you added.
Ronak Patel
Rate helpful posts by clicking stars below the answer.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Looks a good idea, is there a config you can post showing the same.
Blue
What is your call controling application, is it cme or CUCM.
Ronak Patel
Dont forget to rate posts which you think are useful to you.
CUCM. I am using SIP between CUCM and Voice Gateway. I prefer to use all the translations in Voice Gateway, rather than CUCM.
VIP Super Bronze
The best thing to do is to use prefix from the routelist/route route group in cucm. The impliction of this is that you will need to create different route patterns for phones on Both DDi ranges. What this will do is to seperate the called number at the gateway, you can then create dial-peers that match the called number and send the call out the correct PRI intereface. I dont see how voice translation rule will help you here...
example..Phones (phoneA) on DDI 777888XXX will have access to RP with Route List/route group prefixed with 85.
phones (phone B) on DDI 555777XXX will have access to RP with RL/RG prefixed with 75..
so when Phone A dial out the called number will arrive on the gateway with 85XXXXXXXX (where XXXXX is the called number from the user) This will be totally transparent to the end user.
You will then configure a dial-peer as follows (just an example)
dial-peer voice 100 pots
destination-pattern 85..............
port 0/0/0:15...
So the called number will go out the pri for the user...
Please rate all useful posts
"'Nature is too thin a screen, the glory of the omnipresent God bursts through it everywhere"-Ralph Waldo Emerson
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
167
