Corlist
Hello
Here is my corlist configuration. We need to restrcit User 'A' to Local calls only, but corlist is not working as expected. user 'A' can call local / national / international.
dial-peer cor list International
member Local
member 911
member National
member International
dial-peer voice 10 voip
corlist outgoing Local
destination-pattern 1[2-6]......
session target ipv4: 10.10.10.100
dial-peer voice 11 voip
corlist outgoing National
destination-pattern 10[4-6].......
dial-peer voice 12 voip
corlist outgoing International
destination-pattern 100[2-6].........
Voice register dn 10
number 6610
mwi
Voice register dn 11
number 6611
mwi
Voice register dn 12
number 6612
mwi
voice register pool 10
id mac 1111.1111.1111
number 1 dn 10
cor incomming Local default
username A password ????
voice register pool 11
number 1 dn 11
cor incomming National default
username B password ????
voice register pool 12
number 1 dn 12
cor incomming International default
username C password ????
thanks
Anthony
1 ACCEPTED SOLUTION
Corlist
try to update the outgoing naming only
remove the above one and make it as per bellow
dial-peer cor list Local-call
member Local
dial-peer cor list National-call
member National
dial-peer cor list International-call
dial-peer cor list 911-call
member 911
update the dial peers with the above names example:
corlist outgoing Local-call
for testing try to apply the incoming cor on the ephone-DN it self without using the default keyword:
Ephone-dn x
Number xxx
Cor incoming Local
for more information see the blow link:
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_configuration_example09186a008019d649.shtml
hope this help
if helpful Rate
Re: Corlist
hi anthony
there are some steps mising see below
1- define the COR
dial-peer cor custom
member Local
member 911
member National
2- outbound COR lists
member Local
member National
member 911
3- incoming COR lists ( to be applied under the lines/devices)
dial-peer cor list CORInternational
member Local
member National
member 911
dial-peer cor list CORNational
member Local
member National
member 911
dial-peer cor list CORLocal
member Local
member 911
and apply the incoming cor lists above and give it a go
hope this help
Corlist
Hi Marwanshawi
Doesn't work yet, here is updated config
name Local
name National
name 911
name International
member Local
member National
member 911
dial-peer cor list  Cor-Local
member Local
member 911
dial-peer cor list  Cor-National
member Local
member 911
member National
dial-peer cor list  Cor-International
member Local
member 911
member National
number 6610
mwi
number 6611
mwi
number 6612
mwi
number 1 dn 10
cor incomming Cor-Local default
number 1 dn 11
cor incomming Cor-National default
number 1 dn 12
cor incomming Cor-International default
am I applying the 'cor incomming' command in the right place.
thanks
Anthony
Corlist
member Local
member National
member 911
Ephone-dn x
Number xxx
Cor incoming Local
hope this help
if helpful Rate
Corlist
Thanks. It works without the default keyword
387
