Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Corporate Directory &Extension Mobility Service Not Available
Hi Folks,
Using CUCMBE 6.1(2)
Problem is some phones display these fine but the majority do not. Have reset phones, restarted UCM, added directories url's individually to the phone configuration, restarted services all to no avail. The enterprise parameter is correct and I can browse to the urls fine. The phones have web access enabled and the phone loads are also the same but a small majority display ext mobility and corporate directory fine and are configured exactly the same as the phones which do not. Help appreciated, Thanks in advance
Re: Corporate Directory &Extension Mobility Service Not Availabl
Hi!
If all the configuration is the same between the working and non working phones, you ca get a sniffer trace from one non working phone after you press the corporate directory or the EM service.
Were there any changes at all? Was this working fine before?
Are the non-working phones using VPN connection?
Teresa.
Regards, Tere. If you find this post helpful, please rate! :)
Hi Folks,
Restarting the TFTP service and then the phones has resolved the issue
156
