Corporate Directory First Name issue
We just upgraded our CM 4.1.3 to SR4b. Now when we go to Corproate directory we can not look up using First name. It always returns everyone listed. We can look up by Last name and Ext number.
Does anyone use SR4b and have this issue? and /or a work around?
1 REPLY
Re: Corporate Directory First Name issue
Check the following:
Enable All User Search :
This parameter determines whether to allow a search for All Users (search with no last name/first name/directory number specified) when searching for users via the Corporate Directory from the phone. This parameter also applies to the directory search on the Cisco CallManager User Options window (CCMUser). This is a required field.
Default: true.
User Search Limit :
This parameter specifies the maximum number of users to be retrieved from a search in the Corporate Directory feature on the phone. This parameter also applies to the directory search on the Cisco CallManager User Options window (CCMUser). Using values greater than the default value (64) may negatively impact Cisco CallManager performance. Search does not apply when the Enable All User Search enterprise parameter is set to False and no criteria are set for the search. This is a required field.
Default: 64.
Minimum: 1.
Maximum: 500.
129
