Corporate Directory Issue
I am using CUCM 9.1 MS AD directory synchro.
Most of user moves work well except two of them.
Removed from AD
Then they appear as "Inactive LDAP Synchonized" (ok)
Then they disappear from CUCM end users  (ok)   but are till present in Corporate Directory.
We've tried to create them again in AD then synchonize the CUCM then suppress them and so on.  They are till in the Corporate Directory.
Is there any way to manually delete them from directory database ?
Thanks in advance.
If you do not wish some
If you do not wish some people to show up on directory, then you need to create an LDAP filter on CUCM, see:
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/srnd/collab10/collab10/directry.html#wp1084415
Chris.
Hi, Thank you for your
Thank you for your answers but, Chris, I am not talking about filtering users. Theese users are not in the LDAP Directory, not in CUCM end users but are till in the global directory.
I agree that this seems to be a bug and I am going to open a case.
Hi,I misunderstood the issue,
I misunderstood the issue, OK, now it is all clear, I've seen this when there is a table mismatch on the DB replication, try the following from the CLI on all servers:
utils dbreplication reset all
HTH.
Chris.
Hi Chris, Being out of office
Hi Chris,
Being out of office very often, I have to schedule this action at my customer at the end of the week after business hours.
I am surprised about the command to try,  for me this command stand for resynchronizing database between the Publisher and the different Subscribers.
In my case only the Pub is impacted, the global directory is running on the Pub which is itself synchronized on the MS ActiveDiorectory.
Could you please precise it.
Hi,Did you tried the 'utils
Did you tried the 'utils dbreplication reset all' on all servers? if so, what was the result? did you check for DB table consistency?
Please let us know what is the status on this, this case sounds interesting.
Chris.
VIP Super Bronze
Guy,I am leaning towards
Guy,
I am leaning towards "this looks like a bug". Once users are purged after been inactive for 24hrs, they should not be in the corporate directory, unless you have ticked the box Convert User Account to local user, in which case any inactive LDAP user is converted to a local user...
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Hi Chris,
81
