Corporate Directory loads slow on 7940/60 phones
When you press the directories button, it takes a good 10 seconds for the corporate directory to be listed in the menu. It used to appear in about 1 sec, but that was before the DST patches were installed according to the client. This only affects their 7940/60 phones. Their 7941/61 phones display the corporate directory in about 1-2 seconds. Any thoughts??
Chuck
Re: Corporate Directory loads slow on 7940/60 phones
Hmm, I am experiencing the exact same thing. ALL our phones load it slowly now, across all sites. It did seem to occur recently, but I cannot verify it was when the DST fix was applied. It certainly could be at that time, but it also might just be a coincidence.
I also have a department that is loading fast dials slowly now, although it loads just fine for me, so that could just be a congestion thing.
Anyone have any thoughts on this issue?
The new SR5a release fixed it for us last night. Hope that helps. (We are using CM 4.2)
172
