Highlighted
Community Member
Corporate Directory on CUCM 8.6
Hi voice team,
     I am with the following problem: Only the model 7942G does not access the corporate directory the message (host not found), the other models usually access. I realized that only this model tries to access the corporate directory via https://CUCM_IP:8443/ccmcip/authenticate.jsp, others access via http on port 8080. How to fix this?
Thanks.
1 ACCEPTED SOLUTION
VIP Super Bronze
Thiago,
This is where the problem is. The TVS
2445
cur1sr07
The TVS entry is a hostname, which is why you're getting the host not found because your phone isn't configured for DNS or cannot resolve that name.  The fix is to change under System > Server, the hostname to an IP address there, save it, then restart th Trust Verification Service (TVS),
Please rate all useful posts
"There is a wideness in God's mercy Like the wideness of the sea.There's a kindness in His justice Which is more than liberty"
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Thiago,
That is definitely interesting. One, that this phone model is going its own way and two that is going the authenticate.jsp application instead the correct corporate direct url (xmldirectory.jsp). My UCM 8.6 lab system is offline at the moment so I can't check locally. However, this is either a config issue or a bug.
First, if you have a 7962G, check that phone. The 7942G and 7962G run the same firmware. If the 7962G is OK, check the device defaults page to ensure you are using the same version of firmware across both platforms.
Next, check to see if your 7942G is configured to use a different provisioning model for services (Internal, External, Both). Compare it to a known good. Check the device level and the phone template assigned. Focus on differences.
Next, I would pull the 7942G's TFTP config file from the TFTP server. You can use any TFTP client that is allowed to communicate to your UCM. Pull the config down and look inside. Compare it to a known working config. The config file is a little bit of a beast but there is a section for phone services (like the directories) and you are basically comparing to see what's different there (if anything).
Finally, I would test a theory and see if you can get the 7942G working by bypassing the Enterprise Subscription. Provision a sample phone for External services provisioning. Then go to that phone and "hardcode" the directories URL to point to the correct application. You can copy from Enterprise Parameters, just make sure that you are using IP address or a hostname that the phone can resolve. See if that causes the phone to go where you want it to. This isn't a solution but a test that will help determine whether you are dealing with a software issue or not.
If you find strong indication of a software defect then Tac is where you should go. Or, if you wait a little while I am sure Mr. Huffman will come in with the bug ID (he is a master at the bug query).
HTH.
Bill
http://ucguerrilla.com
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
VIP Super Bronze
Thiago,
Can you do the ff: From a windows machine run the following command
tftp -i 10.1.1.1 get SEP0000DEADBEEF.cnf.xml
change 10.1.1.1 to your cucm ip address, and sep00000..to one of the 7942 phone mac address.
If you are using windows 7 you will need to enable the tftp client feature...You can run this command to enable it if you have admin rights..
dism /online/enable-feature/featurename:TFTP
Please attach the config file.
Super Bronze
Depending what model phones you have in your org, this may or may not be strange.
If it happens that the 7942/62 is the only model modern enough to support ITL then that's likely where the problem is.
It is possible to disable the https access, but not generally a good idea as you are only masking the problem.
Perhaps:
1) Respond with the list of other phone models that you have
2) Verify whether your 7942s trust the TFTP service (best way is to assign the phone a new CCM group, and then verify that it correctly registers to the new primary CUCM - if it does not, then you have a problem)
3) Try restarting the TVS (Trust Verification Service) on the server that the phone is registered to, restart the phone, and try it again.
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Community Member
Hi, the models that I have here are: 7911, 7937, 7941 and 7921, these models the corporate directory works perfectly. Here in the company, we only have a CUCM, i restarted the TVS and the phone, but doesn´t work.
Thanks.
Community Member
Hi, I use Win 7 and I have permission, but I could not run these commands.
Hall of Fame Super Red
Hi Thiago,
I'll just add one more note to the great tips from Bill, Deji and Aaron (+5 each guys )
In CUCM 8.x there is a new config setting for Secure Directories that it appears
the 7942 is trying to use. This is where I would start looking;
Overview
Prior to Cisco Unified Communications Manager Release 8.0, Cisco Unified  IP Phones and services did not support HTTPS communication over port  8443.
For Cisco Unified Communications Manager Release, the following features support HTTPS:
Extension Mobility
Extension Mobility Cross Cluster
Manager Assistant
IP Phone Services (See the "Phone Configuration Settings" section.
Personal Directory (CCMPD)
Change Credentials
To support HTTPS in Cisco Unified Communications Manager Release 8.0(1),  the Phone Configuration Settings include the secure URL parameters  shown in Table 3-9.
Table 3-9     Phone Configuration Settings for Secure URLs
Field
Description
Secure Authentication URL
Enter the secure URL that the phone uses to validate requests that are made to the phone web server.
Note If  you do not provide a Secure Authentication URL, the device uses the  nonsecure URL. If you provide both a secure URL and a nonsecure URL, the  device chooses the appropriate URL, based on its capabilities.
By default, this URL accesses a Cisco Unified CM User Options window that was configured during installation.
Leave this field blank to accept the default setting.
Maximum length: 255
Secure Directory URL
Enter the secure URL for the server from which the phone obtains  directory information. This parameter specifies the URL that secured  Cisco Unified IP Phones use when you press the Directory button.
Note If  you do not provide a Secure Directory URL, the device uses the  nonsecure URL. If you provide both a secure URL and a nonsecure URL, the  device chooses the appropriate URL, based on its capabilities.
Maximum length: 255
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/rel_notes/8_0_1/delta/security.html#wp1105189
Make sure this entry is not set as NULL
Cheers!
Rob
"Show a little faith, there's magic in the night" - Springsteen
Community Member
Hi, follow the config:
Secure Authentication URL : https://CUCM_IP:8443/ccmcip/authenticate.jsp
Secure Directory URL: https://CUCM_IP:8443/ccmcip/xmldirectory.jsp
This right, or should I delete this information and let the 7942 using http 8080.
Thanks.
Hi Thiago,
I would copy the url into notepad to save a copy and then try deleting
this setting so the 7942 can use the 8080 non-secure setup
Cheers!
Rob
Community Member
OK Rob, I'll do it, I will do outside of working hours because the phone will restart to apply, but thanks for the help.
After I communicate if this action is worked.
Thanks.
VIP Super Bronze
Thiago,
Yes it is a good start to delete the secure url, but dont forget to restart tftp service so that the phone can downbload a new url.
Community Member
Ok, thanks a lot, as soon as possible, I will perform these procedures then I notice if it worked.
Thanks.
This thread has me pondering a couple of things. Perhaps I should load 8.6 sooner rather than later but here is my understanding of these various URLs from a 8.5 perspective.
First, if a phone is configured for "Internal" services provisioning then that station would not be using the directory URL (or SURL) configured on the device level or Enterprise parameter level. They would use the Corporate Directory that is configured with Enterprise Subscription.
Second, I have found that you can put a non-secure URL (i.e. http://blah:8080/xmldirectory.jsp) in a Secure URL parameter field and it will still work. The only think that makes it 'secure' is the label field;-) The phone uses the field (as provided in the TFTP config file) as-is. I found this out when deploying a custom Corp Directory application for  customer.
Maybe I am slightly off topic, but I felt inspired by the thread.
-Bill
Community Member
Ah, ok Willian, i will do that.
Thanks.
Community Member
Hi voice team, i made a test, removing the Secure URL config on Enterprise Parameters, i reset the TFTP and the phones, but the model 7942G still can not access the corporate directory.
What i do now?
Thanks.
VIP Super Bronze
Does it still show host not found? What URL is it trying to access? Can you do this test. Delete a single 7942, re-add it and test again
Community Member
Yes, the same message "Host not found", the url is http://CUCM_IP:8080/ccmcip/xmldirectory.jsp the same that other models use.
I will do that test, then I'll let you know what the result.
Thanks.
Community Member
I delete the phone 7942 and create again, but still does not access the directory.
Thanks.
VIP Super Bronze
Can you please send the logs on the phone. You will see them by clicking on the ip address of the phone in cucm. Please attach the logs here
Community Member
Following the log: the language is Portuguese.
14:34:51 SEP88F07789E39E.cnf.xml.sgn(HTTP)
14:34:52 Limite esgotado p/DNS cur1sr07
14:34:53 VPN Not Configured
14:34:54 Limite esgotado p/DNS cur1sr07
14:35:00 Sem IP de servidor DNS
14:35:00 Trust List Updated
14:35:00 SEP88F07789E39E.cnf.xml.sgn(HTTP)
14:35:01 Limite esgotado p/DNS cur1sr07
14:35:02 VPN Not Configured
14:35:02 Limite esgotado p/DNS cur1sr07
The DNS its not configured on CUCM.
VIP Super Bronze
I was hoping to see the full logs, but since they are in portuguese, then they wont be useful. Can you put the url for directory access : http://CUCM_IP:8080/ccmcip/xmldirectory.jsp (on the phone itself) There is a place where you can set this on the phone and try again.
Community Member
Hi, i put the URL on "but still does not access the directory.
Community Member
is that the problem may be in the DNS, because it has no DNS configured in CUCM, but as he is directly accessing the IP address I do not see why this error.
VIP Super Bronze
Thiago,
The best thing to do now is to download the phone configuration file and we can see whats in it.
To enable tftp client do this
open Control Panel > Programs and Features > click Turn Windows features on or off in left side > enable  Client TFTP then click in OK
Please attach the phone config file here
Community Member
Hi, following the phone config:
true
SCCP
true
2011h
tzupdater.jar
SNR - Brasil
Brasil GMT -3
D/M/Y
E. South America Standard/Daylight Time
America/Sao_Paulo
10.0.0.253
Multicast
CMGroupSNR
true
cur1sr07
CallManager SNR
2000
5060
5061
2427
2428
cur1sr07
Disable
Disable
false
2000
2000
2000
5060
5060
5060
false
000000
Off
Disabled
120
2445
cur1sr07
true
SCCP42.9-3-1-1S
falsefalse10100011010050510000000011
00
1342031101-10c6d576-1b01-47ab-9942-3b2c3dfac568
Portuguese_Brazil
23
pt_BR
8.6.2.1000-1
iso-8859-1
Brazil
Brazil
http://CUCM_IP:8080/ccmcip/authenticate.jsp
http://CUCM_IP:8080/ccmcip/GetTelecasterHelpText.jsp
http://CUCM_IP:8080/ccmcip/getservicesmenu.jsp
https://CUCM_IP:8443/ccmcip/getservicesmenu.jsp
96
false
false
*81
*82
*83
*84
*85
00089
Missed Calls
Application:Cisco/MissedCalls
Voicemail
Application:Cisco/Voicemail
Received Calls
Application:Cisco/ReceivedCalls
Placed Calls
Application:Cisco/PlacedCalls
Personal Directory
Application:Cisco/PersonalDirectory
Corporate Directory
Application:Cisco/CorporateDirectory
Ativar/Desativar Ramal
http://CUCM_IP:8080/emapp/EMAppServlet?device=#DEVICENAME#
VIP Super Bronze
Thiago,
2445
cur1sr07
Community Member
Thats rigth,it worked with the Model 7942, thank you very much.
Att.
Thiago Gandara
VIP Super Bronze
Thiago ! Hurray!!!!!!!!!!!!!!!!!!!!!!! I love it when we solve problems like this...We never give up! Excellent News! How do you say Vamos! in portuguese?
Community Member
Yeah, never, ever give up, we say: É ISSO AÍ..
Thankssss a lot...
Best regards,
Thiago
Outstanding.  Good work aokanlawan (+5). This thread is a good example of why CSC is the best tech support forum out there. Just sayin'...
Bill
10466
