VIP Super Bronze
Corporate Directory on CUCM 8.6
Does it still show host not found? What URL is it trying to access? Can you do this test. Delete a single 7942, re-add it and test again
Please rate all useful posts
"There is a wideness in God's mercy Like the wideness of the sea.There's a kindness in His justice Which is more than liberty"
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Highlighted
Community Member
Yes, the same message "Host not found", the url is http://CUCM_IP:8080/ccmcip/xmldirectory.jsp the same that other models use.
I will do that test, then I'll let you know what the result.
Thanks.
Community Member
I delete the phone 7942 and create again, but still does not access the directory.
Thanks.
VIP Super Bronze
Can you please send the logs on the phone. You will see them by clicking on the ip address of the phone in cucm. Please attach the logs here
Community Member
Following the log: the language is Portuguese.
14:34:51 SEP88F07789E39E.cnf.xml.sgn(HTTP)
14:34:52 Limite esgotado p/DNS cur1sr07
14:34:53 VPN Not Configured
14:34:54 Limite esgotado p/DNS cur1sr07
14:35:00 Sem IP de servidor DNS
14:35:00 Trust List Updated
14:35:00 SEP88F07789E39E.cnf.xml.sgn(HTTP)
14:35:01 Limite esgotado p/DNS cur1sr07
14:35:02 VPN Not Configured
14:35:02 Limite esgotado p/DNS cur1sr07
The DNS its not configured on CUCM.
VIP Super Bronze
I was hoping to see the full logs, but since they are in portuguese, then they wont be useful. Can you put the url for directory access : http://CUCM_IP:8080/ccmcip/xmldirectory.jsp (on the phone itself) There is a place where you can set this on the phone and try again.
Community Member
Hi, i put the URL on "but still does not access the directory.
Community Member
is that the problem may be in the DNS, because it has no DNS configured in CUCM, but as he is directly accessing the IP address I do not see why this error.
VIP Super Bronze
Thiago,
The best thing to do now is to download the phone configuration file and we can see whats in it.
tftp -i 10.1.1.1 get SEP0000DEADBEEF.cnf.xml
change 10.1.1.1 to your cucm ip address, and sep00000..to one of the 7942 phone mac address.
To enable tftp client do this
open Control Panel > Programs and Features > click Turn Windows features on or off in left side > enable  Client TFTP then click in OK
Please attach the phone config file here
Community Member
Hi, following the phone config:
true
SCCP
true
2011h
tzupdater.jar
SNR - Brasil
Brasil GMT -3
D/M/Y
E. South America Standard/Daylight Time
America/Sao_Paulo
10.0.0.253
Multicast
CMGroupSNR
true
cur1sr07
CallManager SNR
2000
5060
5061
2427
2428
cur1sr07
Disable
Disable
false
2000
2000
2000
5060
5060
5060
false
000000
Off
Disabled
120
2445
cur1sr07
true
SCCP42.9-3-1-1S
falsefalse10100011010050510000000011
00
1342031101-10c6d576-1b01-47ab-9942-3b2c3dfac568
Portuguese_Brazil
23
pt_BR
8.6.2.1000-1
iso-8859-1
Brazil
Brazil
http://CUCM_IP:8080/ccmcip/authenticate.jsp
http://CUCM_IP:8080/ccmcip/GetTelecasterHelpText.jsp
http://CUCM_IP:8080/ccmcip/getservicesmenu.jsp
https://CUCM_IP:8443/ccmcip/getservicesmenu.jsp
96
false
false
*81
*82
*83
*84
*85
00089
Missed Calls
Application:Cisco/MissedCalls
Voicemail
Application:Cisco/Voicemail
Received Calls
Application:Cisco/ReceivedCalls
Placed Calls
Application:Cisco/PlacedCalls
Personal Directory
Application:Cisco/PersonalDirectory
Corporate Directory
Application:Cisco/CorporateDirectory
Ativar/Desativar Ramal
http://CUCM_IP:8080/emapp/EMAppServlet?device=#DEVICENAME#
VIP Super Bronze
Thiago,
This is where the problem is. The TVS
2445
cur1sr07
The TVS entry is a hostname, which is why you're getting the host not found because your phone isn't configured for DNS or cannot resolve that name.  The fix is to change under System > Server, the hostname to an IP address there, save it, then restart th Trust Verification Service (TVS),
Community Member
Thats rigth,it worked with the Model 7942, thank you very much.
Att.
Thiago Gandara
VIP Super Bronze
Thiago ! Hurray!!!!!!!!!!!!!!!!!!!!!!! I love it when we solve problems like this...We never give up! Excellent News! How do you say Vamos! in portuguese?
Community Member
Yeah, never, ever give up, we say: É ISSO AÍ..
Thankssss a lot...
Best regards,
Thiago
Outstanding.  Good work aokanlawan (+5). This thread is a good example of why CSC is the best tech support forum out there. Just sayin'...
Bill
http://ucguerrilla.com
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
11011
