Hi Guys,
We are running CM 4.13 and the Corp Directory works fine on all our 7940s, 7960s and 7970s.. However, whilst the option does appear on our IP Communicators it does not load..
Strangely, it does not produce any error messages, it just flashes up with "Requesting " briefly and then nothing..
I see that there are several threads already regarding problems accessing the Corporate Directory via the Softphone.. However, there does not seem to be a clear resolution for the problem..
Is this likely to be a problem with the softphone being on a different VLAN ( as its loaded on a laptop) to the physical phones ??
Also, does the 7962 phone not support this function either ?..
any advice would be appreciated.. Thanks in advance..
Jon.
