Community Member
Corporate Directory on UCM 9.x
All,
I recently migrated an old CM to an existing cluster.  The desire was to have to separate corporate directories but I now have one with all users listed.  Is there any way to get separation so that I have 2 different directories?
Thanks.  Replies rated.
1 ACCEPTED SOLUTION
No, the built-in corporate directory is not configurable at any level, you would need to write down your own directory scripts for that to happen.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
1 REPLY
java
java
95
