Corporate Directory Service not Accessible from 6945 phone
Hello Everyone,
1-     I have a phone 6945 Load ID SSCP6945.9-3-1-3,   CUCM version 9.1.
Phone is not showing corporate directory all other phones with the same firmware are working fine. (Enterprise Subscription is enbled)
2-     Another phone with the same model and firmware is not showing Call History (Placed calls, Missed Calls, received Calls etc.) Enterprise subscription is enabled.
Can someone share any experience/thoughts on this.
Asad
Re: Corporate Directory Service not Accessible from 6945 phone
Looks like you hitting this DDTs but its opened and your phone load is different
CorporateDirectory does not work on 6945 with 9-3-3-2-ES1
CSCug96587
for second issue check this thread
https://supportforums.cisco.com/thread/2165224
try upgrading to latest firm for one of the phone and check
Br,
Nadeem
Please rate all useful post.
Br, Nadeem Please rate all useful post.
There are several phones with the same model and firmware but they are all working fine. Only two have been reported to have this issue. If it is bug , should't it hit every phone?
Hi Asad,
I had this happen and factory restoring the phones resolved the issue.
HTH,
Chris
If only a couple of phones are affected then it looks to be a phone specific issue. You can try swapping the switchports of working and non working phones and also try a factory reset as suggested by Chris.
Manish
274
