Community Member
Corporate Directory
I have 5 CCM clusters with 5 Corporate Directories. Is it possible to create a replication agreement in SQL from one CCM to the others and sync the directories? I'm tired of updating 5 CCM directories.
Re: Corporate Directory
the directories are not even pulled from SQL/informix so no.
if you use AD you can have them share the same AD containers.
if DCD/informix you can only replicate between cluster servers.
otherwise create a custom script and provide the 5 options for search or create one very customized script to search all servers
java
if this helps, please rate
java
www.cisco.com/go/pdi
Community Member
thanks that helps.
185
