Corporate Directory
The CUCM 7.1  cluster is intergrated to AD. Users are able to search phones  number from the Corporate Directory Service. This is working only when the publisher is up. Becasue the Directory URL is pointing to the publisher ip address in the enterprise parameter. I dont want to use Load Balancers here. Basic idea is to access the information directly from AD.
I want to know more about the SDK's for accessing the Directory from the Active Directory instead of pointing it to the Publisher. If any one has already done this let me know.
Krishna.
1 REPLY
Super Bronze
Re: Corporate Directory
If you did create another web service yourself, you'd still have the same problem where whatever web server hosts the service would need to be load balanced in some way.
An easier option may be to simply  do this:
1) Set up two DNS records for an alias, such as 'ccm' - so create one A record 'ccm' pointed at the pubslisher, and another A record 'ccm' pointed at the subscriber. DNS will then return both names to requesting clients (i.e. the phones).
2) Set your URLs in enterprise parameters in CCM so that the publisher hostname is replaced by the DNS name created above (i.e. ccm)
3) If one server goes down, the phones can access the other IP returned by the DNS server; there may be a delay while they retry.
Aaron
Please rate helpful posts...
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
152
