Community Member
Correct Config for CME connection to Switch
Could anyone tell me if this config looks OK
I am setting up the Interfaces for both our CME 2821 Router and C3560 Switch
The CME Router has IP address, our 3950 switch uses VLAN 20 for voice and the native VLAN for data.
So far I have:
For the CME Router port connected to the Switch
interface GigabitEthernet0/0
ip address
h323-gateway voip interface
h323-gateway voip bind srcaddr
For the Switch Port connected to the Router:
interface GigabitEthernet0/1
switchport access vlan 20
switchport mode access
srr-queue bandwidth share 10 10 60 20
srr-queue bandwidth shape 10 0 0 0
queue-set 2
mls qos trust cos
auto qos voip trust
Is QOS required for the Switch connection to the Router, or can I remove it?
Also Do I need spanning-tree portfast on the interface?
Re: Correct Config for CME connection to Switch
if u have tow vlans where u do intervlan routing
on the switch or the router
if it is in the router u need to make switch link to the router as trunk and in the router inter face creat two subinterfaces one for voice vlan and another for data vlan
for qos u need at lean the followin g command i nthe uplink to the oruter
mls qos trust dscp
good luck
Community Member
I have set up InterVlan routing on the Switch rather than having sub-interfaces on the Router.
The CME uses (the Switch IP) as its Gateway to access the Data VLAN.
Do I remove "mls qos trust cos" from the Switch interface and replace with "mls qos trust dscp"?
Is the rest of the config OK?
Community Member
Can anyone confirm the above? Thanks, Chris
You should configure 'mls qos trust dcsp' on the switchport connected to the gateway, this will simply replace the 'mls qos trust cos' command on the interface.
If you have spanning-tree configured on your switch, then yes it is recommended to enable spanning-tree portfast on this port. This will ensure that the port does not go through the STP listening/learning cycle when the port comes up.
If you are using Inter-VLAN routing on switch, then the switchport connected to the gateway should be a memeber of the respective voice vlan 20 (If this 192.168.1.x).
The CME router only requires the default route to the Switch SVI if connectivity is required to the Data VLAN as you have mentioned.
Hope this helps.
