Correct SIP configuration on CUCM 7.1.3 for Skype Connect
Looking through old posts rthere were references to the way to setup the SIP trunk for Skype connect on CUCM 7.1.3, the referenced documents on Skype no longer seem to be available.can anybody help me with the correct configuration, there must be some documentation somewhere!
Blue
HI
Please see if below link helps you.
https://supportforums.cisco.com/message/3520779#3520779
Please note :- This solution is not tested by Cisco so may not be supported in production case.
Ronak Patel
Please rate helpful posts.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Ronak,
thanks for your response, but i think I might go back to my original idea of using SkyStone H323 gateway, looks a lot simpler to configure
Blue
It is your wish.....Hoep everything works for you.
You may rate the post by clicking the stars below the answers.
Ronak patel
421
