Community Member
Correct Upgrading CUCM (6.1(1) -> 6.1(2))
Hello!
Pls advice me the correct order of upgrading CUCM.
Is this correct:
6.1(1) -> 6.1(1b) -> 6.1(2) -> 6.1(2)SU1a
or
6.1(1) -> 6.1(2) -> 6.1(2)SU1a
Community Member
Re: Correct Upgrading CUCM (6.1(1) -> 6.1(2))
Now i have the System version: 6.1.1.2000-3
Hi Valery, according to the following compatibility matrix a direct upgrade from 6.1.1 to 6.1.2 is supported, and then you can apply the latest service update:-
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/compat/ccmcompmatr.html#wp40122
Here is a reference taken from the release notes for upgrading to SU1:-
Upgrade all servers to Cisco Unified Communications Manager 6.1(2) and make sure that the servers are online before you begin this SU installation; otherwise, pre-upgrade checks may fail or return faulty information. This SU is built from the base 6.1(2) release of 6.1(2.1000-13) and Cisco only supports upgrades from that version.
Hope this helps.
Allan.
104
