Could not add voip dialpeer in cme9.1
Hi All,
I was trying to add voip dialpeers and i am getting this "error could not add dialpeer" i have seen some threds with relates to this problem it was describing  to decrease the maximum dns in the telephony service i have the max-dn 201, max-ephones 165 configured so if i do this in the production environmbent does will it effect my existing phones configured on the cme9.1 2921 router.
Re: Could not add voip dialpeer in cme9.1
You might want to check your log buffer on your CME. I had this exact issue in the past and reducing the size of the logging buffer cleared that particular issue for me.
VIP Super Bronze
Every dial-peer consumes memory, as does the logging buffer and many other things. Assuming you haven't hit the max-ephone / max-dn quantity the router is likely out of memory.
Please remember to rate helpful responses and identify helpful or correct answers.
160
