Could not dial when off-hook except on-hook
I have a weird situation that I could dial to internal extension when i pressed the extension number first followed by the speaker button. However, when I press the speaker button first and hear a dial tone, I could not get connected to the extension when I dialed finished the number.
Any idea? I am using CM6.1.2.1112 with IP phone 7941, 7961 and 7970.
cheers,
TA
Re: Could not dial when off-hook except on-hook
yes, what happens if you wait 15 seconds???
does the call connect???
if so, you have overlapping dial plan
reason it works the other way is CUCM already knows you're done dialing,
java
if this helps, please rate
java
www.cisco.com/go/pdi
What Firmware are you using on your Phones?
The latest 8.4.1SR1 has a stange behavior when dialling ON-Hook
Steffen
140
