02-23-2014 03:12 AM - edited 03-16-2019 09:51 PM
HI ALL;
I AM IN SERIOUS PROBLEM. I AM USING C220-M3 ucs server and have been deployed two servers. CUCM 9.1 AND UNITY CONNECTION.
Unfortunately, I cannot connect to vsphere. I retarted management agents , management service but problem is same. I also checked on switch level everything is fine even I can access CIMC. All Vms are working properly but only thing is can't access to managemant of VSphere.
Can't restart hardware keeping in mind if again same problem appears how i can start my vms. Can anyone tell me the solution ?
02-23-2014 03:24 AM
Can you post the error when u try to login to the Management Vsphere Client.
Sent from Cisco Technical Support Android App
02-23-2014 09:19 AM
connectivity is there. I told that I can connectt o to CIMC which is also on same vlan. I can't even ping to VSphere client ip address.
I can connect to CIMC and can enter to ESXIe Management Interface by click on Lauch KVM Option. I have checked evrything on switch level all are fine.
02-23-2014 03:29 AM
http://kb.vmware.com/selfservice/microsites/search.do?language=en_US&cmd=displayKC&externalId=1003870
