Couldnt get report using CDR.
rajpoovakode
I couldnt get report through CDR. Please help me out with steps for configuration of CDR . I am using CCM 4.2
Adrian Saavedra
Level 7
Level 7
Hi friend,
Check this doc, may be useful for you:
CDR Analysis and Reporting:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/service/4_2_3/ccmsrva/sacar1.html#wp1037699
-- adrián.
follow this doc to check you have it correctly configured
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a008056bd4e.shtml#cause2
if not, configure it the right way and wait until tomorrow to run reports.
javalenc
if this helps, please rate
java
Thanks a lot javalenc , I am checking the congiguration . I will let you know the result.
