Community Member
CounterPath Bria iPhone with CME (multiple extensions?)
I'm using CounterPath Bria iPhone 3.0.1 with my CME 8.6 and it works fine. However, it seems that only one DN is supported. When calling the second extension (4000) the iPhone doesn't ring. Has anyone got this working?
voice register dn  4
number 4000
name Johannes (iPhone)
no-reg
label ISDN/intern (SDN4)
voice register dn  5
number 5000
no-reg
label ISDN/intern (SDN5)
voice register pool  5
id mac 5555.5555.5555
number 1 dn 5
number 2 dn 4
template 1
presence call-list
dtmf-relay rtp-nte
username 5000 password <removed>
description x5000
codec g722-64
no vad
1 ACCEPTED SOLUTION
Re: CounterPath Bria iPhone with CME (multiple extensions?)
Hi Johannes.
Did you register also the second line on softphone as another account?
Let me know.
Carlo
Please rate all helpful posts "The more you help the more you learn"
Hi Johannes.
Let me know.
Carlo
Community Member
Hi Carlo,
thanks, I didn't see this obvious solution. I made two accounts and it works.
476
