Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Court Calls Callmanager version 7.0
Actually we are working on version 7.0 from callmanager but we are presenting troubles with courts calls inbound and outbound, we try to allocate more resources on gateway but more strange is that also occurs locally cut and wit especiffc model 7911.
someone something about of a same trouble?
what is the recomendation analysis to do for obtaind a success result.
Best Regards
2 ACCEPTED SOLUTIONS
Re: Court Calls Callmanager version 7.0
Review debugs and traces to pinpoint the issue
java
if this helps, please rate
www.cisco.com/go/pdi
Hall of Fame Super Silver
What is "court" call?
java
122
