06-27-2012 05:01 AM - edited 03-16-2019 11:52 AM
Good day.
Is there any way to make cisco 3905 work with asterisk?
Cant find any config examples.
Thank you.
07-02-2012 07:46 AM
If some1 will have same problem:
Config file from 7911 works just fine.
Remember to change "transportLayerProtocol" to 2 if you dont have tcp support enabled.
button="1">
button="2">
08-15-2012 10:10 AM
This is great, but guys, my device even doesn't ask for an TFTP.
How did you make it ask for a file from tftp server ?
Previous models are asking this by default, but this one requests IP address, and goes to 'unprovisioned'.
I tried 'next-server' option without a 'filename', just to loook what files it's interesetd in, but still all I got is silence after an IP renewal.
Upd: Got it. Now its able to register on the *, and I'm make exactly one call, after that it goes to 'registering' loop and doesn't answer anymore. And doesn't ring.
Upd2: after removing the
08-15-2012 10:10 AM
Can you explain the procedure ?
which file is required ?
philippe
10-08-2018 03:38 PM
This problem with TimeZone that only showed GMT +0 also happened to me, but the problem is solved in latest firmware updates.
In my case, just updated CP-3905 FW from 9.2.1.0 to 9.4.1 SR2-2 and problem solved, TimeZone just works fine now.
02-05-2013 11:47 AM
Helo Alendarder
Do you have a procedure to configure cisco 3905 work with asterisk ?
thanks
07-31-2014 11:35 AM
Hi Alex,
do you happen to have a procedure fore this? I'm currently trying to achieve the same goal. Regards!
05-14-2015 09:59 AM
01-04-2017 06:28 AM
Hi Kurt,
Thanks very much, I had the same problem with CP 3905, have edited the file now every thing works. I appreciate you support.
JM
10-30-2018 01:25 AM
Do need a firmware of 3905 to work with asterisk?
09-15-2017 05:54 AM
Hi, thank ou for sharing the config file, now I would like to know how doi I send the file to the Phone, I have searched all around manuals and forum, but no clue, is there any reference or small explanation available?
Thank you in advance.
08-20-2018 04:28 AM
10-30-2018 01:26 AM
