CP-7942G displaying wrong time, CME 8.1
CME 8.1  - IOS ver 15.1(2)T1 - All IP phones (type 6921, 7962) are showing the correct time (according to the time zone) except the  7942G (it shows the GMT time without the zone from the router or from the telephony service applied). On the 'Device Information' the phone does not shows any time zone although the time-zone command under telephony-service is there.
telephony-service
cnf-file location flash:
cnf-file perphone
load 7942 SCCP42.8-4-4S
load 6921 SCCP69xx.8-5-3-0
time-zone 30
time-format 24
date-format dd-mm-yy
MAC Address18EF639E4723
Host NameSEP18EF639E4723
App Load IDjar42sccp.8-5-4TH1-6.sbn
Boot Load IDtnp42.8-3-1-21a.bin
VersionSCCP42.8-5-4S
Hardware Revision11.0
Model NumberCP-7942G
UDIphone
Cisco Unified IP Phone 7942G, Global
CP-7942G
V06
Time13:15:15
Time Zone
Date10/12/10
Everyone's tags (3)
1 ACCEPTED SOLUTION
VIP Super Bronze
Re: CP-7942G displaying wrong time, CME 8.1
Kholevas,
Do you have the type command set under the ephone for the 7942..??
eg..ephone 1
mac xxx.xxx.xxx.xx
type 7942...
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Hall of Fame Super Red
Hi kholevas,
This is not an uncommon issue that should be quite fixable
Troubleshooting Incorrect Time Stamp on IP Phones in Cisco Unified CME
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/troubleshooting/guide/ts_time.html#wp1053981
After changing the time-zone setting you could follow these steps.
Usage Guidelines
This command works with the vendorConfig section of the Sep*.conf.xml configuration file, which is read by the phone firmware when the Cisco IP Phone is booted up. Certain phones, such as the Cisco Unified IP Phone 7906 , 7911, 7931, 7941, 7942, 7945, 7961, 7962, 7965, 7970 , 7971, and 7975, obtain Coordinated Universal Time (UTC) from the clock of the Cisco router. To display the correct local time, the time display on these phones must be offset by using this command.
This command is not required for Cisco Unified IP Phone 7902G, 7905G, 7912G, 7920, 7921, 7935, 7936, 7940, 7960, or 7985G.
For changes to the time-zone settings take effect, the Sep*.conf.xml file must be updated by using the create cnf-files command and the Cisco IP phones must rebooted by using the reset command.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/command/reference/cme_t1ht.html#wp1023398
under the telephony-service -
no create cnf-files
create cnf-files
Then reboot the individual phones
Cheers!
Rob
Hi Rob,
Thanks for your answer. I've been working with the problem for hours and i think i went through all of the steps but the 'wrong time' is still there. Any idea what to check?
Hi kholevas,
Hmmmm....
Have you tried reloading the router?
Cheers!
Rob
VIP Super Bronze
Kholevas,
eg..ephone 1
mac xxx.xxx.xxx.xx
type 7942...
Correct!!!
After all those changes, restarts, removes etc the phone type were not on the ephone config !!!!
Thank you very much.
Hi, do you know what the fix was?
thanks
VIP Super Bronze
You need the "type 79XX" where XX=the phone model. You need to configure thi son the ephone configuation in CCME
ephone 1
mac xxx.xxx.xxx.xx
type 7942
Hi Kholevas.
Hi Kholevas.
Could you please share the trouble shoot step for the issue that you were facing, it might be help us also the same to shoot out the issue.
the command type 7942 worked
the command type 7942 worked for me!!! hurrah!!!!!! thanks!!!
I had a similar issue; in a
I had a similar issue; in a CME version 7 I did the follow:
1.- configure time-zone GMT -6 an "sumertime recurring" on global configuration
2.- Configure time-zone at "telephony service" proccess
3.- save configuration
4.- erase cnf-files
5.- create cnf-files again
6.- restart phone
At this, issue still occur; but -after all- with a factory resset the telephone has the correct time on it's display
Hello. I have CME 8.6 and was
Hello. I have CME 8.6 and was problem with phone 7942 7961:
telephony-service
1. cnf-file location flash:
2. time-zone change
3. cnf-file perphone
4. no create cnf-file
5. create cnf-file
6. restart phone.
13586
