CP-7960G Not displaying time on Web interface
Hi Guys,
Cam across this will trying to correct the time. I wanted to confirm that the time was actually correct...thing is, the other phones display the time...but this one does not display time on the web interface. Is this normal?
Everyone's tags (5)
1 ACCEPTED SOLUTION
Blue
What firmware and CUCM/CME version you are running. I suspect firmware issue. May be you can upgrade it and see if it gets resolves.
regards
Ronak patel
Rate helpful posts.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Blue
regards
Ronak patel
Rate helpful posts.
Thank you. It was a firmware issue
381
