CP-7985-PAL + 6 x UL vs. CP-7985-PAL-CH1
I have a dummy question. I have a customer that want to by a Cisco 7985G IP Phone registered to a Cisco CallManager 6.1 and I don't know what to offer. The CP-7985-PAL + 6 x ULs are all I need to register CallManager 6.1? If yes what is the reason of CP-7985-PAL-CH1 witch if more expensive?
Can you provide some documentation related to this subject?
Thank you in advance,
Dan
Hall of Fame Super Red
Re: CP-7985-PAL + 6 x UL vs. CP-7985-PAL-CH1
Hi Dan,
This is actually an excellent question :) With the release of CCM 5.x the licensing for IP Phones changed. For all 3.x and 4.x versions the CH-1 (Channel) License was used and now phones use DLU's (Device License Units)
So, this part;
CP-7985-PAL-CH1 = Cisco Unified IP Phone 7985G for PAL channels with 1 user license
Is needed when purchasing any IP Phone to be used with "older" CCM Versions.
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/phones/ps379/ps6564/product_data_sheet0900aecd8030e546.html
Hope this helps!
Rob
Hi Rob,
thank you for your answer. I know the new license methods, but my problem is why the bundle is more expensive than sum of parts at LP.
Here an example:
SW-CCME-UL-7985= is 300$
CP-7985-PAL= is 3595$
3895$
but the bundle:
CP-7985-PAL-CH1 is 3945$
So, if it is a price difference for the similar products (as you say) then it should be a functionality difference because I don't see why I have to bye a bundle witch is more expensive than sum of parts. Am I right?
This is the motif that I don't know what to offer to avoid the installation problems.
Thank you,
Dan
Hey Dan,
No worries my friend! Pricing is always a little funny isn't it ;-)
The one thing to note here is that the;
SW-CCME-UL-7985
Is a phone/user license specifically for CME (Callmanager Express *denoted by the "E" in CCME) so perhaps this is why there is a difference in price.
Hope this helps!
Rob
263
