CP-8831 displays incorrect time
I just installed an 8831 conference phone in my CUCM 9.1.1 environment. The phone is registered and everything works but the time is off. It's seems like it is using GMT instead of my time zone.
I've verified the device pool has the correct date/time group. As a matter of fact other phones in the same device pool have the correct time. I've tried disabling device mobility but that didn't make a difference. I created a new device pool but no change. This is the only SIP phone in the network so I'm wondering if there needs to be some other option enabled somewhere.  Anyone have any ideas where to look?
Rolf
Silver
Hi Rolf,Have you tried
Hi Rolf,
Have you tried factory resetting the phone just to start from a clean slate?  Can you supply any logs from the phone?
Hope this helps
Tony
Please rate helpful posts
Tony
Hi Tony,Yup, tried resetting
Hi Tony,
Yup, tried resetting to factory default, no change. I did notice this in the log on the phone though.
Error updating locale and CTL update failed.
Then I noticed the phone wasn't getting the load file. The file is on the server but it's not pulling it down. I also noticed that the load file name wasn't listed under device > device settings > device defaults so I manually typed it in there but that didn't make a difference either.
Rolf
Hi,What is your actual
What is your actual firmware?
Did you try installing 8831 locale?
http://software.cisco.com/download/release.html?mdfid=284738433&flowid=46257&softwareid=282074291&os=Linux&release=9.3(3)&relind=AVAILABLE&rellifecycle=&reltype=latest
Regards.
Silver
Hey Rolf,It definitely sounds
Hey Rolf,
It definitely sounds like your are having a ITL/CTL issues. I would perform the following on the 8831 -
Apps>Admin Settings>Reset Settings and  then All.  That should factory reset the phone.
Page 15
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cuipph/8831/9_3_3/english/adminguide/CS38_BK_A8C4AC51_00_adminguide-8831/CS38_BK_A8C4AC51_00_adminguide-8831_chapter_01001.pdf
Hope this helps
Tony
Tony
Tony,I did try the reset you
Tony,
I did try the reset you mention already but it didn't do anything.
Emmanuel,
The firmware is SIP8831.9-3-3-5. I did not try installing locale because there wasn't one for USA. I suppose I could try the United Kingdom version. I did however set the network locale in the device pool to United States but again, no change.
Rolf
Hi,I have same firmware
I have same firmware version for all my 8831 and I don´t have anything issue but I installed the correct locale for my country, you can try creating a new date/time group with GMT offset and check the time, maybe the 8831 never change the time and is a hardware problem, I really recommend to upgrade the CUCM Version to 9.1.2.
Regards.
Probably an issue with the
Probably an issue with the phone pulling the config via TFTP.  Can you enable web access and pull the phone's console logs from the web page after a reset and attach?
Brian,Here is the console log
Brian,
Here is the console log you requested.
Rolf
So the logs weren't very
So the logs weren't very detailed on what exactly was going on with the TFTP config download.  Can you check the Network Settings and make sure that the TFTP server is listed properly?
Brian,The correct TFTP
Brian,
The correct TFTP servers are listed.
May be worth downloading the
May be worth downloading the config from the TFTP server and checking that the time-zone setting is in there correctly.  Are you pointing to the publisher first for TFTP?
A known bug: CSCuq48737
The workaround is to use 7911 as reference pool.
How is it same thing?? The
How is it same thing?? The defect that you mentioned is for CME environment whereas Rolf was using CM in this case.
Deepak
Re: CP-8831 displays incorrect time
i have faced same problem, but got fixed once after i reset the security.
You may follow the below path to reset 'Security'
Apps --> Admin Settings --> Reset Settings --> Security.
Let me know the status.
If reseting security didn't work, perform factory reset. It needs to get the right firmware version.
https://www.cisco.com/c/en/us/support/docs/collaboration-endpoints/unified-ip-conference-phone-8831/119143-technote-ip-phone-00.html
MM
I agree with you Chidananda, I have had this same problem in the past and the full blown factory reset didn't correct the issue, only after I individually reset the Security would it pull the correct time again.
yes.. it is strange.. in general Factory Reset should help us but it was not for me too; so tried resetting the Security. :)
430
