10-08-2014 06:21 AM - edited 03-17-2019 12:28 AM
We are testing a couple of 8861 phones with a KEM attached on each, and the KEM keeps intermittently disconnecting on both phones. The phone shows the following message:
"The Key Expansion Module 1 has been disconnected"
Firmware version: sip88xx.10-2-1-16
I would like to know if anyone has experienced this issue and how got it resolved.
Carlos
10-13-2014 06:05 AM
06-22-2015 08:53 AM
Hi Carlos,
I'm trying to configure a CP-BEKEM, fot a 8851 phone, but can´t seem to find an example on how to do it. Can you help me out?
Best regards,
Ricardo
06-22-2015 11:31 AM
Hi Ricardo,
From the phone configuration window, scroll down to "Expansion Module Information", and from the drop down on Module 1 select "BEKEM 36-Buttom Line Expansion Module". Then create a "Phone Button Template" that contains all your new buttons definitions and assign it to the phone.
If you are using Extension Mobility, configure a Device Profile with phone type 8851 and apply the phone button template that you created.
Carlos
06-22-2015 11:49 AM
Thanks Carlos, I'll give it a try.
01-23-2017 11:19 AM
We are experiencing a similar issue to this as we have been testing the 8861. The issue seems to be related not to software in our case, but the hardware. If the phone and the expansion module are flexed the connection between the KEM and the phone is broken which causes the KEM to reboot. Possible solutions include a bracket, glue, rubber bands or tape :) Anyone else come up with a solution?
Mark
