08-22-2013 06:00 AM - edited 03-16-2019 06:59 PM
Dears,,
I face a problem that I have old 7970 with old firmware when I connect it to register to my CUCM
It's try to upgrade but its failed and all I see in the screen is cisco logo and stuck on that, I try hard reset but still same problem ,Also I connect power adapter and its try to upgrade but its failed .
What's the solution for that pls
08-22-2013 06:04 AM
There are countless thread aboiut the same topic, please search before asking.
08-22-2013 06:36 AM
Thanks for ur response
But I already searched and didn't find any solution for my problem
08-22-2013 06:51 AM
Not to be rude, but could you search again? Just to avoing having other do somethign for that is indeed very, very easy.
