CP7970 upgrade firmware from TFTP is failed
Dears,,
I face a problem that I have old 7970 with old firmware when I connect it to register to my CUCM
It's try to upgrade but its failed and all I see in the screen is cisco logo and stuck on that, I try hard reset but still same problem ,Also I connect power adapter and its try to upgrade but its failed .
What's the solution for that pls
Hall of Fame Super Gold
There are countless thread aboiut the same topic, please search before asking.
Re: CP7970 upgrade firmware from TFTP is failed
Thanks for ur response
But I already searched and didn't find any solution for my problem
Not to be rude, but could you search again? Just to avoing having other do somethign for that is indeed very, very easy.
152
