CRA 3.5(3) engine Not strat
mugahid
25: Mar 24 00:15:54.232 AST %MIVR-SS_APP-6-SS_INITIALIZING:Application subsystem initializing:
30: Mar 24 00:15:54.232 AST %MIVR-LIB_EVENT-7-OFF:Disabling DEBUGGING messages
35: Mar 24 00:15:54.232 AST %MIVR-LIB_EVENT-7-OFF:Disabling XDEBUGGING5 messages
36: Mar 24 00:15:54.247 AST %MIVR-LOG_MGR-6-CATALOG_LOADED:Log catalog loaded: Catalog=MIVR_LIB_RMI
327: Mar 24 00:16:14.076 AST %MIVR-ENG-3-UNK:Error in starting the subsystem : SUBSYSTEM_NAME = ICM Subsystem
289: Mar 24 00:16:13.435 AST %MIVR-STEP_PROMPT-7-OFF:Disabling DEBUGGING messages
290: Mar 24 00:16:13.435 AST %MIVR-STEP_PROMPT-7-OFF:Disabling XDEBUGGING messages
291: Mar 24 00:16:13.435 AST %MIVR-STEP_PROMPT-7-OFF:Disabling XDEBUGGING2 messages
292: Mar 24 00:16:13.435 AST %MIVR-STEP_PROMPT-7-OFF:Disabling XDEBUGGING3 messages
293: Mar 24 00:16:13.435 AST %MIVR-STEP_PROMPT-7-OFF:Disabling XDEBUGGING4 messages
294: Mar 24 00:16:13.435 AST %MIVR-STEP_PROMPT-7-OFF:Disabling XDEBUGGING5 messages
295: Mar 24 00:16:13.685 AST %MIVR-LOG_MGR-6-CATALOG_LOADED:Log catalog loaded: Catalog=MIVR_STEP_MEDIA_CONTROL
222: Mar 24 00:16:11.560 AST %MIVR-SS_TEL-6-SS_INITIALIZING:JTAPI subsystem initializing: Version Info=Cisco JTAPI version 2.1(3.3) Release
223: Mar 24 00:16:11.701 AST %MIVR-SS_TEL-6-CTIPORT_RECOV_THR_START:Starting CTI Port Recovery Thread: Recovery Thread id=CTIPortRecovery-0
224: Mar 24 00:16:11.951 AST %MIVR-SS_TEL-1-SS_OUT_OF_SERVICE:JTAPI subsystem in out of service: Failure reason=A number of route points are OOS - all routes; A number of CTI ports are OOS - all ports
david-lima
Level 4
Level 4
Hi friend, i think that your CRA server is unable to initialize the CTI ports or CTI route points through JTAPI.
Please, verify that you have the CTI ports and CTI route points associated with the JTAPI user that you create in your CCM, also validate that the JTAPI user password is the same in the CCM and in your CRA.
Hope this help
David
Hi David
the error message is(JTAPI Subsystem OUT_OF_SERVICE)
263: Mar 24 20:58:35.625 AST %MIVR-SS_TEL-4-ModuleRunTimeFailure:Real-time failure in JTAPI subsystem: Module=JTAPI Subsystem,Failure Cause=7,Failure Module=JTAPI_PROVIDER_INIT,Exception=com.cisco.jtapi.PlatformExceptionImpl: Unable to create provider -- null
264: Mar 24 20:58:35.625 AST %MIVR-SS_TEL-4-EXCEPTION:com.cisco.jtapi.PlatformExceptionImpl: Unable to create provider -- null
thanks MUGAHID
Have a look at the following, http://www.cisco.com/warp/public/788/AVVID/jtapi-startup.html
Unable to create provider -- null - Verify that a host name or IP address is configured in the JTAPI configuration. If the JTAPI version is incorrect, download the JTAPI client from the Cisco CallManager Plugins page and install it on the CRA server
