07-16-2008 05:42 AM - edited 03-15-2019 12:00 PM
I have CRA 4.0, I am able to get the welcome prompt, but when i press 0 to transfer the call to the agent i m not able to get any thing. I m getting error that you have dial the wrong number.
I have installed the agent desktop on the laptop and IPT is assocated with abc user, ICD extension and primary extension box is checked in CM. I am able to login with abc user successfully.
But i m not able to transfer the call to the agent desktop, even dont know the call is coming in the queue or not.
please help me, where i m missing.
Solved! Go to Solution.
07-16-2008 06:50 AM
The aa scripts does not use CSQ. It is an auto attendant script that is used to dial by name, by extension and then transfer callto an operator.
To transfer callt o an operator you need to assign the operator's extesnion.
To do this, go to application>application management>click on the application name...
scroll down to the script section and look at the operExtn, click the check box and insert the operator's phone number inbetween the ""
07-16-2008 08:38 AM
Let me know if your problem is resolved!
07-16-2008 06:09 AM
wasiim,
For you to route calls to a queue in CRA..
you need to do the following: (from subsystems>rmcm
1. Create skills
2. Create Resource groups
3. Create Contact service queue and assign this to a resource group
4. Assign your resources (agents) to the CSQ (Contact service queue ) and assign the skills you created to them
5. You will then go to application management and create a new application, assign it to a script you have created.
NB: In the scripts you must have configured the names amd parameters of the CSQ you cretaed earlier, this is how CRA will route calls to the queue
6. You will then assign a jtapi trigger to the application
07-16-2008 06:37 AM
Thanks for the reply,
1. i have made the skill with name test,
2. in resource tab i can see a user that i made in CM.
3.Test_Resource group also made.
4.Test_Queue is also there, and Resource Pool Selection Model* is group skills.
5.agent(user) is also assing the test skills.
6.Cisco Script Application tab is having
Application Type* cisco application script
max session: 10
script: aa.aef
default script: system script
8.JTAPI Trigger Configuration:
DN: 777
Call Control Group* JTAPI Group #1234(1234)
Primary Dialog Group* Call JTAPI Group #1234
this all i have already done, I am using default values. Please tell me what i m missing.
07-16-2008 06:50 AM
07-16-2008 07:12 AM
thanks for the reply, problem solved. but i have 10 user agent, i want them to answer the calls like in call center.
now i have made a new application and select the icd.aef. and make the new trigger with 888.
after dialing 888 i m getting prompt that all agents are busy, but on agent desktop application i cant see any call in queue.
I am using the same old queue name that i made and i recall it in new application setting.
now please help me how the agent see the incoming calls in queue so that he can retrive the call.
07-16-2008 07:15 AM
one thing more that i noticed is that when call comes agent status become NOT READY, but before the call status was ready.
Why it is so, i think this is making the problem.
07-16-2008 07:16 AM
If you scroll down to the script section under the application you will see a box called CSQ, check that box and put the name of the Contact service queue you have assigned your agents to there
07-16-2008 08:03 AM
07-16-2008 08:06 AM
If your agent states changes to not ready when call comes in, then you need to check the following:
1. CSS of your CTI Ports
2. The partition of your agent phones
You need to make sure that the css of your CTI ports has the partition of the DN of your agents in it.
3. Lastly make sure that your agent phones are not in a region configured for g.729.
07-16-2008 08:38 AM
07-16-2008 08:53 AM
Problem solved, Thank you so much, Now it is working fine. really really thank u very much
07-16-2008 08:56 AM
You are welcome!
Glad to know its working and thanks for the nice rating! Good luck!
