Crappy Call Quality - What to look for in following report......
Hi Guy’s,
We have a branch of approx 10 6921 phones (connected to subscriber via DSL WAN) that are experiencing poor voice quality at a particular time in the afternoon like clock work….
Below is a stream capture of a problem call the I managed to re-create where the caller could hear me fine, however the quality of my audio became un-bearable….
I know that the MOS is quite low but what else should we be looking at?
Remote Address
10.195.0.109/16434
Local Address
10.210.42.60/23512
Start Time
16:23:07
Stream Status
Not Ready
Host Name
SEPC46413FE147E
Sender Packets
7300
Sender Octets
145980
Sender Codec
G.729A
Sender Reports Sent
Sender Report Time Sent
16:19:27
Rcvr Lost Packets
6
Avg Jitter
13
Rcvr Codec
G.729A
Rcvr Reports Sent
Rcvr Report Time Sent
16:19:33
Rcvr Packets
7290
Rcvr Octets
145800
Cumulative Conceal Ratio
0.2984
Interval Conceal Ratio
0.0099
Max Conceal Ratio
0.794
Conceal Secs
129
Severely Conceal Secs
115
Latency
Max Jitter
297
Sender Size
20
Sender Reports Received
9
Sender Report Time Received
16:19:29
Rcvr Size
20
Rcvr Discarded
Rcvr Reports Received
Rcvr Report Time Received
0:00:00
MOS LQK
2.8057
Avg MOS LQK
2.0769
Min MOS LQK
Max MOS LQK
2.9192
MOS LQK Version
0.95
Any advise much appreciated!
Cheers!
Everyone's tags (6)
Jitter is a problem here (as well as the packet loss) That maximum jitter of 297 is huge. You should be aiming for jitter to be a fraction of that.
Jitter is caused when packets are delayed.
Check that QoS is correctly configured on your DSL link. If this is happening like clock-work, it could be that someone/thing is sending/receiving large IP packets, and these are delaying the RTP packets. You need to make sure that your DSL interface is configured to correctly fragment these large IP packets so as not to delay the RTP packets.
GTG
Please rate all helpful posts.
Thanks GR!
But isn't the jitter value in milliseconds? therefore 297 ms should be ok if the 6921 has a jitter buffer between 10 milliseconds (ms) to 1000 ms.
I am off the track here?
Cheers!
The point of a jitter buffer is to smooth out the variation in transmition time/delay of packets. Sure, you can have a 1000ms jitter buffer. But that would mean that the phone has to store 1000ms of voice data before playing it back to the person on the phone. If both ends of the VoIP call have 1000ms jitter buffers, that means it would take over 2 seconds for the person at the other end to respond to a simple "Hello".
If memory serves, you want jitter to be less than 40ms. So your max jitter of just under 300ms is way too high.
Once packets start arriving outside the jitter buffer window, the phone treats the packet as lost, and so either has to guess what the contents might have been, or just give silence. This is when quality starts falling off a cliff.
GTG
437
