Create caller ID in CME 8.6
Calin Lupas
We configured about 40 phones with internal extensions. These extensions have no DIDs and there are 4 DIDs we need to use as the caller ID for outbound. Reading the forums, it looks like the only way to achieve this is by translation rules. However, we cannot apply more than 1 super translation rule to a translation profile and unfortunately, there are 3 super translation rules. Below is the revelant section of "show run". Thank you. for your help.
voice translation-rule 6
rule 1 /3055201$/ /1231237822/
rule 2 /3055204$/ /1231237824/
rule 3 /3055206$/ /1231237824/
rule 4 /3055207$/ /1231238327/
rule 5 /3055208$/ /1231237824/
rule 6 /3055210$/ /1231237824/
rule 7 /3055212$/ /1231237824/
rule 8 /3055215$/ /1231237822/
rule 9 /3055221$/ /1231238327/
rule 10 /3055225$/ /1231238327/
rule 11 /3055226$/ /1231238327/
rule 12 /3055234$/ /1231238327/
rule 13 /3055240$/ /1231238327/
rule 14 /3055243$/ /1231237824/
rule 15 /3055244$/ /1231237824/
voice translation-rule 7
rule 1 /3055245$/ /1231237822/
rule 2 /3055246$/ /1231238327/
rule 3 /3055257$/ /1231237760/
rule 4 /3055261$/ /1231238327/
rule 5 /3055262$/ /1231237760/
rule 6 /3055266$/ /1231237822/
rule 7 /3055268$/ /1231237760/
rule 8 /3055253$/ /1231237760/
rule 9 /3055276$/ /1231237822/
rule 10 /3055289$/ /1231237760/
rule 11 /3055291$/ /1231237824/
rule 12 /3058245$/ /1231238327/
rule 13 /3055256$/ /1231237760/
rule 14 /3058315$/ /1231238327/
rule 15 /3055267$/ /1231237760/
voice translation-rule 8
rule 1 /3058276$/ /1231237760/
rule 2 /3058273$/ /1231237760/
rule 3 /3055270$/ /1231238327/
rule 4 /3055271$/ /1231238327/
rule 5 /3055274$/ /1231238327/
voice translation-profile MAINOUT
translate calling 6
voice-port 0/0/0:23
translation-profile outgoing MAINOUT
-Calin
Nadeem Ahmed
Hello Calin
what is your ios version on this router? i would suggest try upgrade 15.1(4)M which has 100 rules
Router(config)#voice translation-rule 1
Router(cfg-translation-rule)#rule ?
  <1-100>  Translation rule tag
Br,
Nadeem
Please rate all useful post.
Br, Nadeem Please rate all useful post.
Nadeem Ahmed
Hello Calin
Br,
Nadeem
This solved this issue. Many thanks.
-Calin
