12-21-2008 12:46 PM - edited 03-15-2019 03:11 PM
Hi All,
I have not worked a lot with callmanager 4.1. How can I create DN without to create phones? In CUCM, DN can be created without to assign to any phone. can we do the same thing in CM 4.1?
thanks
Alex
Solved! Go to Solution.
12-21-2008 04:25 PM
the DN alone creation is not implemented in CCM, only in CUCM. you'll have to create the phones using another MAC address, then delete them and they will go to unassigned DNs. that is the only way
java
if this helps, please rate
12-21-2008 12:51 PM
ok the question is what the idea in doing this ?
12-21-2008 12:55 PM
thanks for reply,
We have 100 DID range, I'd like to create all extensions corresponded to the DID before to assign to any phone then show admin assistant how to add those DN to the phones. like CUCM 6.1
thanks again
Alex
12-21-2008 02:30 PM
Hi, you can insert the lines/phones with BAT and create dummy Mac address, then you can choose the DN and change it with the correct MAC Address.
Hope this help.
David.
12-21-2008 04:25 PM
java
