Creating a hunt group with analog lines
How do I create a hunt group with four analog lines in Call Manager 4.1?
I have four analog lines going through a vg224 gateway.
1 REPLY
Re: Creating a hunt group with analog lines
You can create a Route List that contains the analog lines then assign that RL to the Route Pattern. That is if you are using MGCP so you can have the ports on CCM.
Another option is to use the preference command on the dial-peer. Create the same dial-peer and assign a preference to each one pointing to different ports.
290
