Community Member
Creating a standalone Voicemail box.
I need to create two standalone voicemail boxes.  They do not need to ring a phone, just straight to voicemail.  I am new to cisco and my search has revealed zero results.
We are using Unity and CUCM, the newest versions of each.
Thanks!
Everyone's tags (3)
Hall of Fame Super Red
Hi Wick,
A nice way to create a "Dummy" or "Virtual" number in CUCM is
create it as a CTI-RP (CTI-Route Point.) When you create a
CTI-RP you will be able to set a CFWD on the DN page to go staight to
VoiceMail
Just a thought.
Cheers!
Rob
"Your life is worth much more than gold."
- Bob Marley
Community Member
Re: Creating a standalone Voicemail box.
Hey Rob,
Thanks for the answer and I will play around with this, but just a bit of background.  I am not a network administrator.  I work in a different part of IT yet all of this has fallen onto me.  There's a lot more to say but I think you get where I am headed.
All of this Cisco administation is new to me, and I have been teaching myself as I go. We just recently switched over to VOIP, using SIP.
Could you go into more detail on how to create this type of number, or if possible direct me to a correct article?
Again thanks for the response!
Community Member
I was able to figure it out Rob,  Thanks anyways!
206
