Creating multiple translation patterns CUCM 8.5
Good day all,
I need to assign an employee a DID number. The problem is that he is in another state and I've only been able to ascertain that our translation pattern is setup for our state and area code. So how would I go about setting up a translation pattern for his area code? Would I need to create another dial peer?
Example:
Our translation pattern is 972934XXXX
I need one that is 770XXXXXXX
Tariq
Hi Tariq.
Is that employee's phone registered on the same cluster?
Is your provider passing 770XXXXXXX DID to your VG?
If yes, you can create a translation pattern on CUCM translating the DID with different area code into desired extensions.
Please let me know
Carlo
Please rate all helpful posts "The more you help the more you learn"
Thanks so much! That was pretty much the answer I needed.
Re: Creating multiple translation patterns CUCM 8.5
Hi Tariq.
Glad to help.
If you think i answered your question, please rate the answer and mark it as answered if it meets your needs.
Carlo
157
