Creating user template
How can I create a user template so that "selected permission information/groups" are tied to the template?
  • IP Telephony
1 ACCEPTED SOLUTION
Re: Creating user template
You can assign group of users to the group role through the User Management - User Settings - Access Control Group
VIP Super Bronze
What product and version? Give us more than a vague one-liner.
Please remember to rate helpful responses and identify helpful or
CUCM 9.1.1, Im looking to create a user template so that "standard ccm end users", and standard cti enabled " permissions  are part of the template and are then automatically assigned once i associate a phone to a user
No way to do that on CUCM, there are no user templates, nor way to tie attributes to users as they're imported from LDAP.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
my apologies, perhaps im not explaining this correctly.   the users are already there, as a result of ldap.  when i associate them with a phone, i have to manually go and give them standard ccm enduser, and standad cti enabled.  Is there a way to tie this to a generic user template to be used for any user
That's what I understood from the previous replies, and thus, the answer remains the same.
There's not even a concept of a user template in CUCM.
java
java
Bulk Administration / User/ User template.  is what i am referring to
yeah, this would work.  thanks to everyone who responded.
149
