Credentials for different SIP providers
Hi All,
We are trying to register two sip trunks with two different providers. We managed to get them registered, but with the configuration in the cisco document, both credentials are sending to both providers, which results in a provider blocking our IP due to multiple wrong logins.
CIN-2921-1#sh sip register st
--------------------- Registrar-Index  1 ---------------------
Line                             peer       expires(sec) registered P-Associ-URI
SIPProvier1                       -1         0            no
SIPProvier2                       -1         0            no
--------------------- Registrar-Index  2 ---------------------
SIPProvier1                      -1         38           no
SIPProvier2                      -1         18           yes
Is there a way I can specify which credential should be used for which sip trunk?
1 ACCEPTED SOLUTION
Please look at:
http://www.cisco.com/en/US/docs/ios/voice/cube/configuration/guide/vb_9655_ps5640_TSD_Products_Configuration_Guide_Chapter.html
Restrictions for Support for Multiple Registrars on SIP Trunks
The Support for Multiple Registrars on SIP trunks feature has the following restrictions:
Old and new forms of the registrar command are mutually exclusive: the registrar can be configured in  either primary/secondary mode or multiple registrar mode—not both.
Dynamic  Host Configuration Protocol (DHCP) support is not available with  multiple registrars (available for primary/secondary mode only).
Only one authentication configuration per username can be configured at any one time.
A maximum of six registrars can be configured at any given time.
A maximum of 12 different realms can be configured for each endpoint.
You  cannot restrict the registration of specific endpoints with specific  registrars—once a new registrar is configured, all endpoints will begin  registering to the new registrar.
You cannot remove multiple configurations of credentials simultaneously—only one credential can be removed at a time.
Jorge Armijo
Please remember to rate helpful responses and identify helpful or correct answers.
-- Jorge Armijo Please remember to rate helpful responses and identify helpful or correct answers.
Re:Credentials for different SIP providers
Can you please share the running configuration from the Cube..
Jagpreet
Hall of Fame Super Silver
This has been asked here several times, did you try searching for similar issue?
Chris
excuse me for my bad searching skills. So is the answer a NO?
Please look at:
Jorge Armijo
227
